Volkswagen diagnosis: Lean mixture code, No apparent drivability issues - NewBeetle.org Forums
Old 11-10-2010, 03:03 PM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
Default Volkswagen diagnosis: Lean mixture code, No apparent drivability issues
Models affected:
Volkswagen: Golf, Jetta, Passat, and New Beetle
With 1.8T, 1.9, 2.0.
Codes stored:
P0133
O2 sensor: slow response Bank 1
P0139
O2 sensor: slow response, Bank 2
P0170/P0173
Fuel trim malfunction Bank 1/2
P0171/P0174
Bank 1/2 fuel trim lean
P1136/P1138
Bank 1/2 long term trim at lean limit
P1141-P1143
Load calculation cross-check limits
All of these faults listed above can be the result of a Mass Airflow Sensor (MAF) that has a contaminated/damaged hot film element. If a MAF sensor is not responding with the correct air density/volume calculation, then the ECU cannot calculate the proper amount of fuel, and the O2 sensor will generate low voltage. In some cases, the ECU will set O2 sensor low activity codes.
Contrary to popular belief, the ECU will not typically set a MAF code, as it is sending a valid but incorrect signal.
The first step in the diagnosis for this vehicle is to check for physical external vacuum leaks while monitoring the fuel trim data. The OBD-II generic mode on the scan tool is best to use for simplification. Do not reset the faults or the fuel trims at this time.
Vacuum leaks are typically found at the fuel pressure regulator hose, defective crankcase ventilation valves (there are several on 1.8Ts), canister purge valves, and brake booster hoses/lines. Once you have corrected any leaks, you can use the fuel trim short-term data to determine if you have cured the issue. If a leak was the cause, then the short-term fuel trim data will become negative, attempting to pull the mixture to a more lean condition, as the prevailing high (above 10%) fuel trim is now too rich to keep the engine running at the appropriate mixture.
The next step is to verify proper fuel pressure. Remember, just because you do not have a drivability problem doesn’t mean your fuel supply system is up to snuff.
If fuel pressure is good, and any vacuum leaks are repaired or not found, yet the fuel trim data has not changed much, then it’s time to take a close look at the MAF sensor.
First, check the meter’s signal at idle. A good running engine should yield the following results in grams per second at idle, with no load. These are known good values, taken from real-world applications.
1.8 Turbo 3-5 GPS
1.9 Turbo 3-5 GPS
2.0 3-4 GPS
Sensor readings that do not fall into this range are out of spec and must be replaced.
The final step in diagnosing the lean running condition is to check the MAF sensor’s calculated load value at wide open throttle. This test is simple; have a helper watch the scan tool as you drive it down the road with the pedal all the way to the floor. If you do not see at least 95% load, the MAF sensor is at fault.
The Bosch hot film MAF that VW uses in these applications is extremely susceptible to contamination from silicone (detailing products), silicates (dust), and oil (usually from a bad crankcase breather element or aftermarket open-style air filter.) They usually do not respond to cleaning, as the hot film will fuse contaminates to its surface, and then effectively insulate itself from airflow.
The Hitachi MAF sensor seems to suffer from these issues less, but the same diagnosis still applies.
After the MAF sensor has been replaced, be sure to double-check your fuel trim to make sure the short-term is in the negative, pulling down the high long-term trim. You can, at this point, reset your fault codes and take it for a test drive.
P0420 code 01 volkswagen beetle with 2.0 ,Catalyst system below threshhold bank 1 jrw2scw 2.0 Liter Gas 2 02-13-2010 10:19 PM
Radio Security Code Issues jerryn Car Audio 54 11-17-2009 03:03 PM
mods to improve drivability mat3833 1.8 Liter Turbo 23 06-20-2008 09:53 PM
Cel Code Diagnosis Crystalgolem 1.8 Liter Turbo 3 09-22-2006 10:50 PM
System Too Lean t22456 2.0 Liter Gas 7 03-08-2006 02:05 AM
