The warning lights were Traction Control and ABS...there is a small chance that the vibrations knocked something loose on the right side of the car, but I bet more then anything the right tires floating over the rumble strips caused a difference in speeds at the right wheels to the left and threw the codes.....
I just got back from looking under the car for anything out of place and noticed my front driver side directional tire is on backwards and is going backwards Its not worn any more than the others but better get that reversed on the rim this weekend. |
That happened to me. It was intermittent for a while and then gave me a hard fault for the Left Front ABS sensor (used Vag-Com to diagnose). Found one on-line from a vendor in Fl. 2 day delivery, 30 minutes install and problem went away. I think it was $14 in parts and 30 minutes my labor.
Good luck
So Many Toys, So Little Time |
I would take it back where you got the tires, if you have had the tires on the car for a few thousands miles, flipping it might cause the belts to shift. If the people that mounted the tires messed it up have them fix it, and make a note so if the belts do separate they have to replace the tire. Also do not let them just replace the one tire, argue it with them, you might be able to get the other front tire replaced by prorating the tire, that way you have two new tires on the front.
I just bought the car last Monday and didn't even notice it at the time. The tires look to be around half life, maybe 60%, so should I even bother at this point?
Its not any more worn than the others and your saying flipping it could actually cause it decay faster? |
Hope the warning lights are as people here said! :O
J'veux pas mourir tout seule. |
| oil warning light came on | jimligia | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 02-13-2010 04:45 PM |
| Warning light | mloeks76 | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 02-10-2010 08:56 PM |
| What is this warning light? | Bigpapagech | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 11-10-2009 04:49 PM |
| Help! Coil warning light | BeccyBug | 1.9 Liter TDI | 12 | 05-20-2007 11:18 PM |
| What's this warning light? | VintageAmore | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 06-26-2006 12:06 AM |
