It's ok to replace just the front or just the backs. The rears are very simple, only takes 30 mins to change the rears and you don't need an alignment afterward, although it wouldn't hurt to align the front and rear if it has been a long time.
Have you done just the back before? Do you remember how much it cost? I am not able to do it myself.. no mechanical skills lol. SO I am looking to bring it to a mechanic.. as long as its not to pricey. So I can have them do just the rear? Shocks and Struts? Not sure what it needs. Just makes alot of nose on bumpy roads.
I have replaced just the fronts, or just the rears on several cars. The rears on the back of the beetle are shocks. They are super simple to replace so I would assume a shop should charge at the MOST 1 hr labor even though it takes 30 mins with the right tools. I would shop around yourself for shocks and then take them to a shop if you're not comfortable doing it yourself. If they charge you more than 1 hr labor, they're crazy and take it somewhere else.
What was the long list of items that needed to be replaced? You can easily spend over $1000 on tires alone, depending on what type of tires you're getting. The cheaper sets will run about $280 a set, plus another $100 for stems, mounting, balancing, tire disposable, ect.
I wouldn't change my front struts without doing an alignment, tires are more expensive than an alignment! Although I did change the struts on my Geo with no alignment and ran it for 2 years after that without a problem, but those little donut tires were only $45 a piece too so it wasn't a big concern to me then.
The cost of an alignment is of no concern, my point is since the front struts come out of the part that gets moved in an alignment and that part doesn't get moved or adjusted, is there any reason for an alignment?
Generally, yes, anytime you remove/replace a major part of the suspension, it's a good idea to get an alignment. I'm sure there are arguments to that statement, but it's better to do it and not need it than not do it and shoulda woulda coulda and get premature tire wear. Chances are that if you are to the point that you need new struts, most likely due for an alignment anyways. Obviously as parts wear, the geometry changes as well. And with strut replacement, you would want to replace the strut mounts as well. Look at the top nut on your strut underneath the "raintray" or cowl cover (whichever you want to call it). There is more than likely a space between the top and the frame of the car (see pic). Thats how much wear is in the mounts. So I would probably change the struts and get an alignment all at the same time.
Hello,
Are you sure it is the shocks in the rear making the noise? It could be many things, like a lose exhaust system. etc. How is the ride? When you hit small bumps does the car feel like its hitting the ground with no rise back up? Is there alot of grease looking stuff around the shocks? These would be signs that the shock is leaking or broken. Can you change your tire on this car? The reason I ask is because as stated above the rears are SOOOO easy. All you do is take off your rim and tire toghether after you jack the car up of course. Take off 3 bolts and replace. Anyone with some mechanical knowledge can do the rears. The Fronts NOT so easy. You have gotten alot of great advice so far. If you cant do it and you want to pay someone to do it. Check your local craigslist posting for mechanic doing side work in your area. Be carefull, watch the whole repair of the car. Some people claim to be what they are not. But again its a simple repair just observe the work. Next if you have the money pay to have them all done as the ride will be alot better. GOOD LUCK
http://newbeetle.org/forums/parts-accessories/44158-unofficial-newbeetle-org-decals-6.html Yes, Im in love with the Beetle. I have owned the NEW Ringo, Rico, JYD, and Peppy Pepper. I love this site and the people that come with it. I hope to see you and your beetle at a GTG soon. |
| Should I replace the springs with the struts? | Nicoliae | 2.0 Liter Gas | 5 | 08-21-2010 05:57 PM |
| Struts? | eliteboi | 1.8 Liter Turbo | 11 | 01-14-2010 03:06 PM |
| Removing Struts, BPR and BPS | sre2094 | 2.5 Liter Gas | 15 | 10-20-2009 03:20 PM |
| Trunk lid struts | Cadenza | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 04-10-2008 02:02 PM |
| Struts? | jc918t | 1.8 Liter Turbo | 1 | 06-12-2007 02:49 AM |
