beetle 2005 convertible driver door cable and window - NewBeetle.org Forums
Old 03-22-2011, 04:58 AM
Question beetle 2005 convertible driver door cable and window
Hi, I have a beetle 2005 and recently had a problem with the cable reel for the driver door to open the car from the inside. I dismantled the inner cover and saw that the cable was torn - How can I change the cable reel especially on the lock-side?
second point: while I was working on the door I realized, that the holder for the glass was loose - I found the screw to tighten this but how strong are you allowed to tighten the screw?
Thanks for help, colan
Old 03-23-2011, 12:10 AM
MyOtherRidesAVette's Avatar
Thumbs up
Hand tight, but I would use "removable" Loctite as the screw has worked itself loose once.
MORAV
In der Automobil-Scheune
Tags
2005 , beetle , door cable , window
Driver Door window not coming down to close door on Convertible zoedica New Beetle Convertible 10 10-14-2010 09:49 PM
2005 NBC Driver Door Lock and Mirror Daniel A. Musaraca New Beetle Convertible 1 09-13-2010 03:57 AM
Driver side electric window switch,door light and door lock not working. Bug2003 Questions, Issues, Concerns, or Problems with the New Beetle 6 06-13-2009 12:51 AM
2004 NB Convertible Driver Window rjags4 New Beetle Convertible 2 02-26-2009 01:28 AM
2004 Beetle Convertible ... Driver-side Window along B-Pillar not sealing! redbugger New Beetle Convertible 12 04-26-2007 02:17 AM
