Hey there,
I've had my 2001 new beetle for a year and I've been really happy with it up to now. I have an odd problem. I just went to start it and the battery light flashed and then all the idiot lights started flashing and alternating. It did this a few times and then started making clicking noises when I turn the key. If I open the drivers door the interior light does not come on. I know what you're thinking, it sounds like a dead battery huh? So if I open up the passenger door, the interior light comes on strong. If I turn the key half way and release the parking brake the headlights come on, seem strong. I had just parked it an hour or so after a 30 min 60-70mph drive. I just found this thread: http://newbeetle.org/forums/questions-issues-concerns-problems-new-beetle/2876-wont-start-flickering-indicator-lights.html Now a dead battery would be just too easy. I'm going to unhook it and charge it during the light of day. I'm worried about the driver's door though. Last edited by puzzlin; 02-07-2006 at 06:57 AM.. |
I have the battery on the charger now, but it looks like it has a pretty good charge already. I used a voltmeter on it before I hooked it up to the charger and it was reading 12.3 volts approximately.
I'll let it charge fully and hook it back up. I'm keeping my fingers crossed ![]() |
it seems like it's all over the place..I put the fully charged battery back in, but alas to no avail.
![]() If I turn the key halfway and release the parking brake, the headlihgts come on full power. If I turn the key to start it, it clicks like it's out of power and the interior lights come on real dim. If I try to lock the doors using the remote, it makes the noise, doesn't lock the doors and it sounds really weak. there was a little corrosion on the positive terminal on the battery. I cleaned that off, but it didn't seem to make any differance. The thing that has me really worried is that the driver door when opened does not kick on the fuel pump or the interior lights. If I open the passenger door the interior lights come on, sometimes full power sometimes dim. I dropped it off at the dealership this evening, so we'll see what they say about it tomorrow.. <cross fingers> |
The thing with the drivers door opening and no lights and no fuel pump is actually in the door teh little switch in the door lock mechanism that tells the car the door is open is broken.
THe real electrical demon tho is the starting problem you have. Have you maybe tried to see if the starter cable is connected securely on the starter? Does it start fine when being jump-started? If so, have you tried a new battery?
Ok I took it in and they figured it out.
Apparently the battery was fine until it was under load, as it was shorting out internally. That's why I could charge it and test the voltage with a voltmeter but it wouldn't start. So the symptoms were correct, just sneaky. $235 later I had a new battery. $400 more and they fixed the driver's door switch. Unfortunately neither was covered under the extended warranty. ![]() |
My fuel pump still works. Is it not priming now, but when I start the car it is priming? |
| FS 2001 Bio-Beetle TDI 5sp | Bio-Beetle | Market Place Archives | 4 | 04-19-2006 08:27 PM |
| wanted beetle fog lights | StealthTurbo | Market Place Archives | 0 | 12-09-2005 06:24 AM |
| Won't start - flickering indicator lights! | 1HoopsGirl | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 12-01-2005 03:50 AM |
| 2001 Beetle TDI GLS | AnthonyLyndaker | Market Place Archives | 6 | 11-16-2005 07:26 PM |
| Beetle Won't Start - Help Please | jiffyjoe | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 10-02-2005 12:26 PM |
