Battery disconnect - 2000 VW New Beetle GLS ? - NewBeetle.org Forums
Old 07-03-2011, 09:58 PM
Car: 2000 GLS - 2.0L - Bright Blue Pearl - 5 speed
Default Battery disconnect - 2000 VW New Beetle GLS ?
per procedure, i am suppose to disconnect the battery before i attempt to install a replacement electric side view mirror switch (the round knob broke off). I know I have to reset the digital clock, the one-touch up and one-touch down power window feature, and re-code the radio with the car's radio code. BUT do I have to reprogram the ECM as well with a scan tool? Actually, I do have the Vag-Com cable and software but haven't really learned how to use it well yet.
Man, I just feel like trying to replace the switch by just removing the door panel and taking my chances on the battery disconnect (not doing it).
Advice?
Thank you,
George
Old 07-04-2011, 11:43 AM
CGK's Avatar
Beetleman
Salisbury, NC, USA
No need to disconnect the battery. That's always put in there just to protect the manufacturer from any liability should something go wrong.
Just do everything you need to to access the plug and replace the switch.
The only time you really need to disconnect the battery is where you're working on electrical components in the engine i.e. alternator,starter,etc. or wiring in accessory components that require tapping into the fuse or relay block.
Old 07-04-2011, 06:37 PM
Hackster's Avatar
Vehicular Curmudgeon
Upstate, SC, USA
Car: 2000 GLS 2.0 5-speed
I disconnected mine the other day to repair a couple of airbag/seatbelt sensor wires under the seat the other day. No worries.
John
Old 07-04-2011, 06:47 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Disconnecting the battery for a prolonged period of, i don['t know how long, will RESET your ECU.
I replaced my door mirror knob and didn't disconnect the battery to do it
The reason a lot of people disconnect the battery is because of the fear of the airbag going off. I have taken out the center radio pod, swapped the bumpers for votex one's and had my seats re-trimmed and swapped over and never had an airbag go off
It's like if you buy paracetamol and the leaflet inside says, "You may suffer from blindness, heart attack, itching of your ass " It's just to protect VW
Go ahead and change it
If the airbag goes off i'll eat my 4th of July hat
Old 07-04-2011, 06:49 PM
Blugg's Avatar
If i did those mods i guess i would disconnect the battery
Old 07-04-2011, 06:57 PM
Hackster's Avatar
Upstate, SC, USA
Mmmmm... Mods? (Unless those wires breaking is so common that fixing them is considered non-stock... )
Old 07-04-2011, 07:23 PM
Blugg's Avatar
You mentioned Air-Bag
That is the only time i would definitely disconnect the battery..
Any other time i just rip it out, do what i have to do, then put it back, hoping the airbag goes off, so i can start a thread (With photo's) on here of what i did and what happened
Too much " Oh no, what happens if i jump off this mountain into that paddling pool below " on here
Old 07-05-2011, 01:32 AM
Default battery disconnect
thanks for advice guys - I agree - George
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Battery works, but turn ignition and battery dies...won't start without boost Buffet Boy 2.0 Liter Gas 11 07-13-2012 01:33 AM
Battery Disconnect? WolfieG Car Audio 2 01-09-2010 12:36 AM
What if I disconnect the battery? Duffy 2.5 Liter Gas 6 10-28-2009 01:42 PM
My Readiness wont set after battery disconnect ninsei 1.8 Liter Turbo 3 01-01-2009 12:17 AM
Aftermarket Radio inop after battery disconnect 2002bug0220 Questions, Issues, Concerns, or Problems with the New Beetle 1 05-19-2006 05:53 AM
