I just bought a 1999 NB GL ,and the rear hatch only can not be unlocked by the electronic way.When I pressed the switch at the door or open it ,I heard "CLICK" from the lock of the hatch ,but it does not be unlock .And when I press the button of my E-key to try to open the trunck ,it does not work at all,even no "CLICK".What's wrong?
Also,it seems the indicator light of the seat-belt does not work at all.It will disppear no matter the belt is fastend or not.Is that OK? How it works in a proper way? Please help me ,Thanks a lot |
The seat belt indicator is just a little reminder light (it's gets really annoying in latermodels where it almost forces you to wear it), but in '99, it's only stays on for a few seconds after you turn the key. So it will turn off with ot without the seatbelt on, it is normal.
Thank you all for help me .And I'm glad to kown the indicator isn't "broken".I held the button of the door mounted e-fob and my friend tried to open the trunk meantime ,it does not work .The lock of the hatch seems realy broken,I think it maybe need to be fixed. Anyway ,thanks a lot .This is a real wonderful place !
after the panel is off, try unlocking it both ways and see whats not happening (or what is happening that is not supposed to be). tell us what you find! ![]()
Thank you for your suggestions.I pried the panel off and found the small motor fell off.So I repluged the motor .The door-mounted switch works now !!!
But the middle button of the key doesn't work ,it seems the remote control cann't drive the motor.No matter how I press or hold the button,there is no response at all.But I can use the other two buttons to lock or unlock the door ,so I think it is not the problem of the key battery.Can I open the key, how to do that ? Or it is the problem of the electronic system inside the car? Thank you all for your help!! ![]() |
if you have a second remote, though, you could try unlocking the trunk with it to see if it's just a bad button or if its a system problem. |
Switchblade: On the back of the key (where the VW logo is), there is a small slot to insert a screwdriver to pop it apart. Once you halve the remote, pry the remote portion apart. On the thin side, two cells.
-Des |
Thank you all first !Finally ,all my problem about the hatch were solved.I think the reason I failed to open the rear hatch was I made a mistake,I didn't hold the button of the key for enough time before .I am sorry about this . I don't have any manual
Thanks again ! Have a good weekend! |
| Hatch won't latch | karmann72 | Questions, Issues, Concerns, or Problems with the New Beetle | 33 | 12-09-2011 04:49 PM |
| Help With Rattling Rear Hatch | flat4tom | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 04-20-2007 07:36 PM |
| Please HELP Different Trunk, Hatch Latch problem | lee157 | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 02-10-2006 05:41 AM |
| WTB: Rear donut style head rests (creme) & Rear Hatch Cover for '01 NB GL | Ice06 | Market Place Archives | 0 | 12-21-2005 06:10 PM |
| After market CD changer in rear hatch area? | Beetlebomb | Car Audio | 3 | 10-10-2005 09:44 AM |
