ABS control unit part number - NewBeetle.org Forums
Old 02-13-2006, 01:13 PM
GREECE,
Car: 1,6 -May 2000
Default ABS control unit part number
The vag com gives me that this unit have problem,,,the number is
1CO 907 379 J but the dealer says that this is a wrong number,,,know anybody how can i find the right number...thanks a lot brothers
Old 02-13-2006, 04:17 PM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
I can't help you with the part number, but didn't Zookie have the same problem and replaced the expensive ABS unit only to find out it was something else that was wrong? Might want to research it a bit more before spending the money.
Old 02-14-2006, 10:31 AM
GREECE,
Car: 1,6 -May 2000
yes my man,,,,it is expensive,,,,here in greece... 1050 euros for a new one!!!too much,,,,and i try too find the serial number...i am sure that has problem this unit...i've check it twice...
Old 02-14-2006, 03:36 PM
PurpleHaze's Avatar
Riverview, New Brunswick, Canada
Car: 2000 New Beetle TDI
Before replacing the expensive ABS unit find out if it has power going to it. One of the cables that are on top of the battery fuze box is a power cable that feeds the ABS unit. Now if you pull up on the box to jump the battery or replace it this cable will break at the point where it enters the box but you can't see the break thus the computer shows that the ABS unit is dead. Had mine go after I got a boost due to a dead battery, dealer said it was the ABS unit and wanted to order one in to fix the problem, I had checked into this and found a thread that said check the power. Had the dealer check this out which they did under protest and they found the broken cable. I have heard of several other people that have had this same problem and the simple fix is the cable.
Old 02-15-2006, 10:35 AM
GREECE,
Car: 1,6 -May 2000
I had replace my battery before 3 months....i think that the dealer do good job....but i'll check it again...I have to told you that the lights ABS and ESP is OFF when i drive...when i push the brakes and ABS must be in use they turn ON and wink...When it be in this condition i plug VAG-COM and gives me the error ...I am afraid that i've got to buy a new one contol unit... thanks a lot for your advice
Old 02-16-2006, 07:10 PM
Zookie's Avatar
Vapor Transmission
Mississauga, Ontario, Canada
Car: 2004 Porsche 996 C4S
Replace all you Fuses on top of your Battery Box. If it does nto work, PM me have a ABS Control Module and ABS Hydraulic Pump for sale.
Old 02-17-2006, 10:59 AM
GREECE,
Car: 1,6 -May 2000
thanks my man i've checked all tha fuses and they are ok...I am sorry but you are far,,,from me to sent and buy these second hand
stocks Today i went to the dealer and i ordered a new one abs control unit with the above code,,,he says tha maybe have a new one code:ico 907375 L ...i mean that vw has replace it since,,,2000...the price is about 400 euros,,.I ordered and some other stafs like mirror switch and arm latch,,, and right turn light...these silly vw's plastics...I've got to wait until next week to send me to staf....
Old 03-08-2006, 03:50 PM
GREECE,
Car: 1,6 -May 2000
i have to say that they do mistake with the serial number again!!They give one ABS unit controller without esp...And i have to ordered it again it costs,,,about 1050 euros.... all the other staf like mirros switch costs 22 euros all together,,,,
Aftermarket CD unit question redbug119 Car Audio 4 01-27-2006 08:08 PM
Replacing my head unit LadybugEwa Questions, Issues, Concerns, or Problems with the New Beetle 3 12-09-2005 06:17 PM
Headlamp bulb Part Number for '01 1.8T New Beetle racerdeb Market Place Archives 1 12-04-2005 05:43 PM
Head Unit Installation Muse Car Audio 2 11-05-2005 05:30 AM
Number of Posts??? Dede Suggestion Box 3 09-25-2005 03:37 PM
