I have a 2000 Beetle TDI that seems to have no power going to the starter hopeing someone can tell me if there is a relay i should be checking or a fuse or if it ma be something else any help would be appreciated thanks
Is it automatic or standard? Possible clutch switch, neutral safety switch or park brake switch (E brake) maybe.
That's the most basic thing that could cause this, so now that we're beyond that lets go to the more exotic. Battery was out, was it connected properly when replaced? Was the new battery put on a charger before being installed? I know for my new battery that I got this summer for my 98 that I had to put it on my charger for a few hours to get it to full power, it had basically no juice in it. When you go to start, does the electric system function normally, other than nothing happening when you turn the key fully to start the engine, dash lights come on normally? Check the fuse panel, not sure which fuse is the starter, you may need to do a search for a diagram. If the bug was sitting for six months it's possible that with an old starter like that it could have seized up maybe? |
Does the glow plug light come on when you first turn the key? If not, check the glow plug fuse. If the fuse is ok, then most likely relay #19 (main power relay) under the drivers side dash is bad. Look on tdiclub.com for info on it.
Good luck
2007 VW New Beetle 52K (hers) 2002 VW Jetta TDI 137K (mine) 1995 Volvo 850 Turbo 229K (kids) 1983 Mercedes 300D 251K (diesel commuter) 1965 Corvair Corsa 97K (fun car) |
Doubt it would be an Immobilizer issue. The car would crank over and maybe even start, but if the Immobilizer isn't happy, then it shuts the engine off after 1 second of running.
Break out the test light. Unplug the solenoid wire from the starter and see if it lights up with the ignition is turned to the start position. If it lights up, then could be right there with the starter. Does the instrument cluster light up with you first turn the ignition on but then blank out when you go to crank on the engine? Do the interior lights work?
| 2000 TDI tried to start, now won't turn over | GodSendHockey | 1.9 Liter TDI | 6 | 06-23-2011 11:44 PM |
| 2000 Beetle Suddenly Won't Start | new_beetle_lover | 2.0 Liter Gas | 5 | 09-25-2010 08:05 PM |
| Key Fob Remote Problem No Start 2000 Beetle | Irish Wake | 1.8 Liter Turbo | 5 | 09-14-2010 03:14 AM |
| Hard to start 2000 Beetle | mss542 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 10-18-2008 11:49 AM |
| 2000 beetle won't start/doesn't turn over... | sunshine219 | 2.0 Liter Gas | 7 | 06-22-2008 12:32 AM |
