Blinker problem - NewBeetle.org Forums
Old 02-17-2006, 04:01 AM
Gainesville, FL, USA
Default Blinker problem
So I have a question. My friend has an '02 Turbo, and the turn signals turn on about once, and then turn off. Same with the hazard lights. It was first noticed after her dad replaced one the headlights. I checked the fuse, and the fuse is fine, and the same problem exhibits itself when I put in another fuse into the spot (I think it's #38). Anyway, My guess is that there is a cable that is not plugged in all the way somewhere, but I checked in the engine compartment and couldn't see squat (first time I've looked under a VW hood). So if you could point me exactly where to look, or if you have any other ideas, I'd be highly appreciative. Thanks.
Old 02-17-2006, 01:31 PM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Sounds like the hazard switch has failed. It has been happening in some New Beetles. The hazard button that you push to turn the hazards on is the control module for the signalling and hazard system. You just pop it out and unplug it, then just put a new one in. You could put a tester on its contacts to see if the circuits open and close but it is likely that component, its unrelated to the headlights probably just coincidental.
Old 02-17-2006, 02:03 PM
Hmm. Thanks for the idea. I shall have to take my multimeter with me to test it. How would one go about removing it?
Old 02-17-2006, 10:42 PM
Twizzler
You just pry it from its bottom edge and work it out with your fingers, you don't need tools for this. It will eventually pull out into your hand and just reach behind and unplug the connectors.
Old 02-21-2006, 09:31 PM
Yup, that was it. She took it to the VW place and they replaced the hazard switch under warranty.
Thanks guys.
Big Problem! BlackBug 2.0 Liter Gas 4 02-15-2006 06:25 PM
What could be the problem? CyberGrnBug01 1.8 Liter Turbo 2 02-08-2006 10:09 AM
Help me please... what problem is this jitsion 1.8 Liter Turbo 9 12-02-2005 01:02 AM
Blinker gone crazy!!! suzshack Questions, Issues, Concerns, or Problems with the New Beetle 2 11-24-2005 01:04 AM
My 06 TDI has a problem :( Nerd Technical Modifications 1 11-12-2005 12:55 PM
