DC Plug - NewBeetle.org Forums
Old 01-01-2012, 02:48 PM
ghostRder1's Avatar
GA,
Car: 2006 Convertible
Default DC Plug
Leaving a GPS but turned off, plugged into the DC Plug power will this drain battery?
Thanks.
Old 01-01-2012, 04:13 PM
For long enough, yes. The plugs are still powered with the car off.
Old 01-01-2012, 08:46 PM
ghostRder1's Avatar
GA,
Thank you.
Old 01-02-2012, 12:39 AM
VDubYah's Avatar
Orlando, FL,
Thats weird because my plugs are not powered with the key off in either of mine.
Old 01-02-2012, 02:53 AM
They stayed on in my '99 and they stay on in my '03 GTI as well.
Old 01-02-2012, 08:09 AM
ghostRder1's Avatar
GA,
Is there a way to power off the DC? When ignition turned off?
Old 01-03-2012, 12:09 PM
VWBubba's Avatar
Ljubljana, Slovenia
Car: 2000 2.0 Beetle, Mitsubishi Shogun Elegance 3.2 Tdi, Mitsubishi 2.8td Intercooler.
Default Voltage draw
The voltage draw from a portable sat nav is minimal especially when turned off as it will only take what it needs to reach full charge.
It would take weeks to drain the battery . If the car is used daily there will be no problem to the car, on saying this the sat nav should be unplugged and let go flat from time to time to condition the battery. By leaving the sat nav in you risk more damage to the sat nav battery rather than the car.
Steve
Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me, either. Just leave me alone.
Old 01-03-2012, 01:25 PM
Also depends on the age of the battery though. That's how I ended up finally killing my battery. Left the GPS charger in overnight.
I personally wouldn't leave it plugged in all the time. But I also put the GPS away whenever its not being used. Rather not risk the car being broken in to.
Old 01-03-2012, 10:48 PM
ghostRder1's Avatar
GA,
Thanks for replies. I need to try this.
Oil pan plug maxs 2.0 Liter Gas 5 08-04-2011 02:02 PM
What's the Spark Plug Gap? mcgarret1094 1.8 Liter Turbo 2 02-27-2010 04:21 PM
WTB side mkr light plug + lic plate light plug apodaca Market Place Archives 2 09-25-2007 04:09 AM
where to get plug wires? bobbittle 1.8 Liter Turbo 4 10-04-2006 05:39 PM
oil pan plug oldceltjohn 2.0 Liter Gas 1 01-19-2006 07:01 PM
