Front wheel wobble - NewBeetle.org Forums
Old 01-03-2012, 12:13 AM
Exclamation Front wheel wobble
At low speeds my 2004 beetle convertible front drivers side wheel seems to be wobbling there is wobbling noise coming from it, the wheel is tight the noise disappears around 100km (65 miles)
Any ideas what this could be ..
Old 01-03-2012, 12:59 AM
VDubYah's Avatar
Orlando, FL,
Lets see
1. Warped brake rotor
2. Wheel bearing
3. Bent drive axle
4. Bent wheel
5. Bad tire
6. Loose lug bolts
I would start here.
How many miles on the car?
Old 01-03-2012, 01:22 AM
TechnoTrix'd's Avatar
Time 2 get my Bug on. ;-)
Brookhaven, PA, USA
Car: '01 NB TechnoBlue 1.8T GLX - Pepe Jr, 03 G35 - Diamond
Originally Posted by VDubYah View Post
Lets see
2. Wheel bearing
3. Bent drive axle
4. Bent wheel
5. Bad tire
6. Loose lug bolts
I would start here.
Add the inspection of the tie-rod end to the list.
Just sounds like some worn front end bits. With a 2004 it's time to put some $$$ into the front end.
Sent from my Autoguide iPhone app
Hey Click ME! – ToD 2K12 GTG & Cruise - - -ToD North East Bugavan Thread 2k12
Previously Owned Vdubs: '83 Blk GTI (Da' Bomb - moon-roof, ball shift knob, crazy striped interior), '87 Vanagon (Weekender - Brown), '90 Vanagon (Weekender - White, alloys, - one style'n refrigerator on wheels), '08 Graphite Blue Passat LUX.
Old 01-03-2012, 01:26 AM
VDubYah's Avatar
Orlando, FL,
I forgot
7. Ball joint
Old 01-03-2012, 01:39 AM
IndyTom's Avatar
Indianapolis, IN, USA
You also forgot Lower control arm bushings which wear out quickly on the new Beetle's Replace with the Heavy Duty TT bushings.
Old 01-04-2012, 01:11 AM
90,000 miles it's my girlfriends car and I'm pretty sure none of the above have been done I'll check them
Thanks guys
Front end wobble/shake hernws 2.0 Liter Gas 6 08-06-2011 12:59 AM
Front End Wobble Under Braking and at Speed - CV or Brakes beartoothweb 2.0 Liter Gas 5 10-02-2010 12:49 AM
acceleration wobble katy's zeus Transmission Talk 2 02-18-2010 02:25 PM
Non-typical Driver Side Wheel Wobble gies5 Questions, Issues, Concerns, or Problems with the New Beetle 1 10-05-2009 08:46 PM
how do i tell if my beetle is front wheel drive, back wheel, or 4 wheel? crazi_daisy Miscellaneous Hoo-Ha Archive 6 01-02-2006 09:44 AM
