Is it Manual or Automatic? If it is an Automatic make sure it shifts properly and try the tiptronic in manual mode to see if the manual feature works. The early automatic transmissions have been very troublesome and the valve bodies are known to fail. Also ask about the timing belt service. If it hasn't been performed you may want to put it on your to do list. Dealers will charge 1100-1600 Dollars to perform this service but most VW shops charge about 750. Or you can do it yourself for about 254 in parts. Good Luck and let us know how it goes. |
Lol..I just looked through a couple of websites with NB wheels and didn't see them on there
Yes it is an auto, and I've read about the tranny issues so I'm going to take a nice long test drive with it. It only has 49k on it so I assume the TB hasn't been done but, I'll check for records. I did look up the VIN on VW and it still has the recall for the coil on there. |
WOW, pretty low miles for an almost 9 year old car. I am sure it didn't have the timing belt done. Remember it isn't always about mileage. Age has a lot to do with it as well and if the timing belt service hasn't been performed yet it will still have the crappy plastic impeller water pump which has known to disintegrate.
Just look it over real well and make sure it's what you want. Ask them about the coils. There are 4 of them on a 1.8 since they have coil on plug and not just one central coil. Good luck and let us know if you get it. |
| pcv valve question and oil question | a_magoo | 1.8 Liter Turbo | 3 | 10-07-2006 01:31 AM |
| p 0411 code question and coolant leak question.... | bobbittle | 1.8 Liter Turbo | 5 | 06-12-2006 02:47 PM |
