Had the timing belt and water pump changed out at 95K car now has 125K.
If all that is bad is the o-ring. Should I be ok with just replacing it and closing it back up(if it all looks good) or should I do the whole deal again? Thanks in advance for any help or advice! |
Was the water pump replaced with one with a plastic or metal impeller?
Maybe I will just change the water pump, the belt and the stretch bolts. |
If water is coming from the flange around the pump it is the 'O' ring and can be changed. If the water is coming from the center shaft it is the pump seal so the pump will need changing.
My thought (depending on milage you do) If it is just the 'O' ring then change that. If the pump is at fault do the belt too. Why spend over $100.00 when a 50 cent 'O' ring will solve the problem? Biggest money is in the pump so to buy the belt too is only a Spaghetti Western so it is up to you.
Steve Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me, either. Just leave me alone. |
| Still leaking coolant!!! | middknight1 | 2.0 Liter Gas | 53 | 03-27-2010 09:23 PM |
| Leaking coolant | middknight1 | 2.0 Liter Gas | 7 | 12-19-2009 06:05 PM |
| water leaking into interior | lomofo | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 10-15-2009 04:17 AM |
| Leaking Coolant, Help!!! | GraceIsotope | 1.8 Liter Turbo | 3 | 07-27-2006 11:22 PM |
| Coolant leaking | bdlbug | 2.0 Liter Gas | 4 | 10-25-2005 11:25 PM |
