radiator fan - NewBeetle.org Forums
Old 01-21-2012, 09:06 PM
Cutie101's Avatar
131,000 miles!
Chapel Hill, North Carolina, USA
Car: 2002 VW 2.0 Beetle silver "Ringo"
Question radiator fan
any tips on replacing the radiator fan? i have the whole assembly i want to install.
>>United States Air Force<<
Old 01-21-2012, 09:31 PM
IndyTom's Avatar
Indianapolis, IN, USA
Just a tip. On the larger of the two fan make sure that you don't have a 4 pin plug. All of the aftermarket assemblys only come with a 3 pin plug and a lot of the earlier New Beetle's had a 4 Pin Plug for the Larger fan.
There really is no easy way to remove the entire assembly. It is a bit of a pain. I think it is easier to remove each fan by itself and then the shroud. But check your original Large fan connector first. It won't do you any good if the original doesn't match your connector.
Old 01-21-2012, 10:24 PM
Miami Lakes, FL, USA
Car: 99 2.0 gls
Have patience.
Old 01-23-2012, 07:44 PM
Cutie101's Avatar
131,000 miles!
mine has three
Old 01-23-2012, 07:47 PM
Cutie101's Avatar
131,000 miles!
maybe i could just put the fans on cause the only problem is one of them is cracked real bad and everytime the fan cuts on it vibrates and makes a really loud noise
Old 01-23-2012, 07:53 PM
IndyTom's Avatar
You can try that. Most aftermarket assemblies don't have the same mounting points or screws as the OEM fans. But give it a try and see. You just might make it work.
Good Luck!
Old 01-23-2012, 07:58 PM
You can certainly just change out the one fan. I've done that myself. Its tricky but you can do it without removing the bumper or anything (which is what the repair manuals tell you to do).
Old 02-16-2012, 08:21 PM
Cutie101's Avatar
131,000 miles!
whatttt how did you manage to do that? its so cramped in ther lol, good job!! im scared to even try. i dont want to mess anything up but its something i gotta do cuase my parents are tired of spending so much money trying to fix my beetle
Tags
radiator fan
radiator cap chunki84 2.0 Liter Gas 6 02-15-2011 10:47 PM
radiator fan. chunki84 2.0 Liter Gas 1 02-13-2011 04:29 AM
radiator, condensor, radiator fan and shroud, ETC mat3833 1.8 Liter Turbo 0 03-03-2010 03:43 AM
radiator, AC condensor, radiator fans mat3833 1.8 Liter Turbo 0 02-12-2009 12:53 AM
WTB NB radiator PunkinBug Market Place Archives 0 11-18-2006 04:27 PM
