Tools for door latch removal? - NewBeetle.org Forums
Old 01-26-2012, 03:27 PM
pa32dude's Avatar
Portland, OR, USA
Car: 2001 NB 1.8L Turbo
Default Tools for door latch removal?
I'm planning on disassembling my door this weekend to troubleshoot door latch problems, and I am wondering what type of bits I need to deal with the three odd bolts on the end of the door: the little one behind the rubber plug that holds in the lock cylinder and the two big ones. They look like some kind of weird spline drive, I tried all the the bits in my "security bits" set but no matches. A Torx T-20 seems to fit the little one OK, so I might get away with that, but nothing close on the big ones.
Thanks in advance...
Old 01-26-2012, 03:43 PM
Caveman's Avatar
Van Buren, AR, USA
Car: 2001 VW New Beetle 2.0L GLS
I know this doesn't answer the question, but what were you having wrong, or what was the car doing?
Old 01-26-2012, 04:58 PM
pa32dude's Avatar
Portland, OR, USA
Doors stopped locking with remote (but they unlock), "auto-lock" when driving stopped working, locking door with key is now definitely all manual.
Old 01-26-2012, 06:27 PM
IndyTom's Avatar
Indianapolis, IN, USA
You need a 12 point "Triple Square bit set" for a lot of different areas of the Beetle. Some of the Autoparts stores carry some limited sizes. Some might even carry a set of the smaller sizes. Or you can order a set with ECS tuning:
Home Page > Search > Triple Square > ES#9011 "Long Reach" Triple Square Driver Set - S15-HBS1406T
This is a long reach set. You can check around someone might have a regular short set as well.
I found this set on Amazon which is cheaper and has 10 bits which will be all that you will ever need.
http://www.amazon.com/Neiko-10-Piece...7606136&sr=8-1
Old 01-26-2012, 08:59 PM
pa32dude's Avatar
Portland, OR, USA
Thanks! I'll try to look around for those locally.
Old 01-30-2012, 04:30 PM
pa32dude's Avatar
Portland, OR, USA
No trouble finding the triple-square bit, they had them at Baxter's (local auto parts chain), I guess NAPA has them at some stores as well. FYI, the bolts that hold in the door lock assembly take an 8 mm bit, the one I got cost just under 4 bucks and has a 3 inch shank that fits into a 1/2 inch socket. I was able to use a T-20 on the small bolt that holds in the lock cylinder.
Disassembling the door was not too difficult, between the Bentley and this post:
How To: Door panel, window regulator and door latch removal
Biggest problem I had was that the last person who removed the door carrier torqued the screws pretty tight and I had to drill one out. I noticed he didn't put all 11 of them back in either, there were 4 missing.
Based on some posts in other VW forums, I disassembled the lock module and checked for bad solder joints, unfortunately they all looked good. Based on an ohmmeter check it looks like the microswitch that senses if the door is latched is broken. One of those posts talked about replacing it with a switch from Radio Shack, but that looked like a dicey proposition. I'm not 100% sure I could get the module back together in working order anyway. With hindsight, I wouldn't recommend attempting to repair it unless you are REALLY careful taking it apart and are broke enough to not want to buy a new module.
So I had to drive my kids' beater Subaru to work today and will swing by the dealer to pick up a new lock module. $199!!!
How To: Door panel, window regulator and door latch removal gforce1108 Questions, Issues, Concerns, or Problems with the New Beetle 44 09-24-2011 03:48 PM
turbo & manifold removal tools? 70autostick 1.8 Liter Turbo 3 05-10-2010 03:59 AM
Radio Removal Tools Question teklein Car Audio 2 07-16-2006 11:36 PM
Looking For Radio Removal Tools MOONDOG316 Market Place Archives 10 02-11-2006 03:00 PM
Removal Tools MOONDOG316 Car Audio 1 01-10-2006 10:53 PM
