Key fob won't unlock??? - NewBeetle.org Forums
Old 02-26-2012, 04:46 PM
Richmond, VA, USA
Car: 1999 Silver New Beetle GLX 1.8T 5 speed ,2007 New Beetle 2.5L 5 speed Harvest Moon RIP
Default Key fob won't unlock???
I'm having an issue with my wifes 07 NB key fob. It will lock the doors and open the hatch but will not unlock the car. I tried my remote and it works just fine. I noticed that the light on her fob isn't flashing red when the buttons are pressed like mine either. Could it just be that it needs a new battery? She tried doing the reset procedure explained in the owners manual with no luck...
Any help would be appreciated...
Old 02-26-2012, 07:45 PM
HarlequinPixie's Avatar
ElectricHarleyHouseOfLove
Currently: Williamsburg, VA, USA
Car: 2001 Batik Blue 2.0 GLS 5spd
sounds like it needs a battery to me
Old 02-26-2012, 08:40 PM
denver, CO, USA
Car: 2001 gls - 2000 gl
Sounds like the fob is worn out I bet you need a new one though I do suggest trying a battery first, battery is cheaper. My fob works but my wife dr door wont lock but sets the alarm she needs a lock assembly. If you do need a new fob do note they have codes I think there are nine different ones if you buy one from the internet make sure the code is the same or you will have a fancy paper weight. You can find the code on the inside of the fob ex. [HLO 1JO 959 753 F] all the characters have to match ex. [HLO 1JO 959 753 A] will not work. It sounds like you know the reset for this already. So if you do need a fob and cannot make the new one work I can help you get it set up? I would suggest if the fob is bad buy one from the dealer this way you will be sure itís correct and will work, a used fob is never good idea. Hope this helps you.
Old 02-26-2012, 11:44 PM
Probably the switch on the board. You can buy the switch at either radioshack or digikey, mouser somewhere like that for some cents but it requires some soldering skill to replace.
Old 02-27-2012, 10:10 AM
nighttrain1974's Avatar
I don't care.....
London, London, United Kingdom
Car: Slammed.
Battery.
Easy to do. Just pull the key apart from each end the pry the bottom piece (with the buttons) open and replace the battery. 2 minute job, max.
Old 02-27-2012, 01:26 PM
Richmond, VA, USA
I'm thinking its the battery as well. Just seems odd that it will lock the car and open the hatch but wont unlock. I'm going to pick up a battery today and give it a shot and go from there. For now I just swapped fobs with the wife so she can get in and out easily.
Old 02-27-2012, 05:26 PM
Richmond, VA, USA
I think the new battery did the trick...the red light flashes at least. I'll know for sure after work tonight when I can test it out. My wife has it at work right now...
Hans- 99 New Beetle GLX 1.8T 5 sp. silver w/black leather,moonroof,Pioneer stereo/speakers,and sub,snowbox deleted, 16" houstons(from the '07)
-RIP- Gretel '07 New Beetle 2.5L 5 speed harvest moon
Blu- 05 NBC 1.8T 5 speed Aquarius Blue
Old 02-28-2012, 01:55 AM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
Our 01 GLX recently started having door lock problems. The key fob seems to work as the alarm is set but the doors will not lock or unlock remotely. Both doors failed at the same time, apparently, which seems odd. Is there a relay for the door locks or am I looking at replacing both door lock actuators? Is there a DIY somewhere for doing that?
b
Old 02-28-2012, 02:19 PM
Richmond, VA, USA
b
Not really sure if there is a relay. Sounds like a possible problem with the door lock module or even the microswitch. Make sure your battery is fresh before trying anything else. My wifes would lock and operate the hatch but wouldn't unlock until I replaced the battery. Now all is good and everything works as it should.
Old 03-12-2012, 01:45 AM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
Replaced the key fob battery to no avail. I guess both actuators must have failed. I do hear a slight click, like a relay working, behind the dash on the drivers side when I try to use the door lock switch on the door.
Is there a DIY thread on the actuator replacement?
Old 03-12-2012, 05:45 AM
IndyTom's Avatar
Indianapolis, IN, USA
Car: 2012 Tornado Red VW Beetle Tsi
Did you reprogram the Keyfob after replacing the batteries?
Do you just have one Keyfob or two?
I couldn't get my 2nd Keyfob to manually program. I used my Vag com VCDS lite to program my second fob. Now I finally got two.
Old 03-12-2012, 06:14 PM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
The key fob is not the problem. It is either the door lock actuators or a relay that controls them. Does anyone know if there is a relay in that circuit?
After looking around a bit I think my problem may be the "comfort control module" because the alarm also goes off intermittantly for no reason. The online parts dealers I had the time to check with did not know what I was talking about. Does anyone know the part number for this item and whether it is a dealer-only part?
Thanks,
b
Old 03-12-2012, 07:03 PM
IndyTom's Avatar
Here are the Relay lay outs per Bentley:
Relay Panels 1998-5/2003 VW New Beetle as Per Bentley
Lower Relay Panel:
Position 1 - Dual Horn Relay - Relay number - 53
Position 2 - Load reduction Relay - NOs - 213,100 or 18
Position 3 - open
Position 4 - Fuel Pump Relay - No 409
Position V - Wiper Washer intermittent - no 377
Position VI - Wiper washer 377
Fuses on lower Relay panel:
A - Fuse for power windows (Red connector)
B - Open
C - Fuse for heated seats
Relays on Upper (auxillary) 13 position relay panel:
Position 1 - Fog light Relay - 381
Position 2 - Rear lid remote unlock motor - 79
Position 3 - Anti Theft Starter lock Relay - 185
Position 4 - open
Position 5 - open
Position 6 - Radio speaker/telephone change over relay
second row
Position 7 - Open
Position 8 - Daytime running light changeover relay - 173 or 53
Position 9 - Open
Position 10- Glow plug relay (Tdi only) - 180
Position 11- Park/Neutral position Relay - 175
Position 12- Power supply (terminal 30b,B+) relay - 109,126
Position 13- Coolant fan control relay -53
Hope this helps.
Old 03-12-2012, 07:08 PM
IndyTom's Avatar
Thanks,
b
No Relay for the Door Locks. It could be your in door lock switch.
Stupid door Switch!! $3 Fix!!! - TDIClub Forums
http://forums.tdiclub.com/showthread.php?p=666727
http://forums.vwvortex.com/showthread.php?1542461
Old 03-13-2012, 02:09 AM
member
Glendale, CA, USA
Car: 2001 GLX (AWV)
Thank you, IndyTom.
Very helpful threads, especially the last one. I'll bet we have the cracked solder problem. My petite wife slams car doors like an angry longshoreman.
b
Old 03-13-2012, 03:23 AM
IndyTom's Avatar
Thank you, IndyTom.
b
LOL The smaller they are the harder they hit.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Key fob won't unlock doors Phaedra Questions, Issues, Concerns, or Problems with the New Beetle 1 12-21-2011 12:43 AM
key won't unlock door gtxwalker Questions, Issues, Concerns, or Problems with the New Beetle 4 07-25-2011 01:15 AM
Doors won't unlock! ashers87 Questions, Issues, Concerns, or Problems with the New Beetle 1 09-14-2009 02:51 AM
unlock other car! hla Questions, Issues, Concerns, or Problems with the New Beetle 4 11-13-2008 06:38 PM
Unlock the HID Thread SMG Suggestion Box 10 07-04-2008 12:41 AM
