blown fuse - NewBeetle.org Forums
Old 02-21-2006, 11:27 PM
Exclamation blown fuse
My wifes '99 beetle has developed a problem with blowing a fuse. It is the 7.5 amp that powers the temp sensor and clock. It worked great until about 2 months ago when it started blowing this particular fuse. Everything else woirks fine. No rhyme or reason to it. The brake warning light on the dash will illuminate and we know the fuse has blown. Has anyone had the same problem and found a fix or does anyone have a clue to where I can start looking?
Old 02-22-2006, 06:52 AM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
I'm gonna move this to a forum with the right traffic. See you there, and Good luck!
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Old 04-08-2006, 02:38 AM
Default Having the same problem
Turn OFF your rear window defroster and see if this keeps fuse from blowing. That is what blows my fuse. The cruise also will not work when the comfort system fuse is blown. My defroster element is good so have not a clue as to why it blows when defroster is turned on.
Also, does your rear defroseter work??
Old 06-29-2006, 10:45 PM
Thumbs up Blown Fuse
My problem has been solved. Seems like the problem was in the brake switch. I found out that there was a recall on the recall, on the brake switch. Took it into the dealership, they did the recall and everything is working like new.
Old 06-30-2006, 12:51 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
Thanks for sharing the solution to your problem. We can now use that info. for future reference...
BOTH headlights die at once- must be a fuse, right??? manoverboard987 Questions, Issues, Concerns, or Problems with the New Beetle 4 10-16-2008 02:18 PM
fuse box location? ChuckDubDub Questions, Issues, Concerns, or Problems with the New Beetle 4 08-16-2006 03:57 AM
anyone have a blown 5 speed? I need some parts off it. Growler Market Place Archives 3 01-17-2006 12:35 PM
Blown Turbo oil seal VR-4man 1.8 Liter Turbo 9 12-15-2005 09:01 AM
Blown Fog Light SCbuggin Questions, Issues, Concerns, or Problems with the New Beetle 3 10-02-2005 11:36 AM
