Help! Red Coolant light flashing red all the time - NewBeetle.org Forums
Old 04-21-2012, 03:29 PM
Default Help! Red Coolant light flashing red all the time
got to drive really far tomorrow and my 2000 2.0 beetle is going crazy.
had small problems with coolant light coming on, took it to mechanic i bought the car off and he said its probably a hole in radiator... since then my car has been consuming a LOT of water, thought it might be air bubbles at first though now ive put in about 30litres of water... surely cant be air bubbles..
the coolant light keeps coming on flashing red.. sometimes it then goes off. sometimes it doesnt. sometimes when i check it the water is miraculously still high..sometimes its empty. sometimes its really hot and bubbles up.
when driving tomorrow how safe is it to ignore the red coolant light? driving up here a 4 hour journey took 7 hours because i kept stoping to look at it at service station to look. really dont want a repeat of that nightmare if it can be avoided
i also have an engine management light which is orange? which im told could mean i have an electrical fault.
Old 04-21-2012, 04:23 PM
Garage
Get to an autozone or the like and get the car scanned for codes. That orange light is likely your check engine light.
Unless you can be certain the car isn't overheating, I'd be nervous about driving that far. Are you noticing any leaks?
Old 04-21-2012, 05:14 PM
VWTBS's Avatar
Corvallis, OR, USA
Car: 2002 New Beetle Turbo S
It's possible that he/she has a leaky expansion tank. Maybe a good idea to replace the entire unit.
Old 04-21-2012, 08:09 PM
IndyTom's Avatar
Indianapolis, IN, USA
Car: 2012 Tornado Red VW Beetle Tsi
Do you see any visible leaks? The radiators on these cars very rarely go bad. It is more than likely the coolant flange or the water pump.
Have you inspected to car to see where the leak is coming from?? How long ago was the timing belt/water pump changed?
http://www.ecstuning.com/Volkswagen-...ange/ES279317/
Old 04-21-2012, 08:41 PM
Evanrude's Avatar
~Feel the Sting~
Longview, WA, USA
I had that a LONG time ago, and it was a faulty thermostat. Cheap part, expensive labor unless you do it yourself. The thermostat on the VW doesn't go in an easy place like on an old Honda.
It's located at the lower end of the hose on the bottom end of the engine block. Good times
Old 04-22-2012, 02:33 AM
Unbeatleble's Avatar
Car: 2000 Beetle GLX
Should have it pressure tested, what they do is attach a connector to where you add coolent, that connector is part of a pump and gauge, pump it up full of pressure and it should hiss out air or coolant where your problem should be, least the mechanic should know this, look at the gauge and see if pressure drops, if pressure doesnt drop, then your coolent is sealed and it's probley just burping out air, but from what I read, if you put in that much water, then there could be a small leak that only can be seen when there is a high amount of pressure(when engine is hot), so pressure testing it should reveal your leak, hope this helps
Old 04-22-2012, 01:08 PM
IndyTom's Avatar
It's only difficult to replace on the 1.8 since you have to remove the alternator to get to the Thermostat housing. Okay, some have done it with just removing some bolts and connecters on the alternator and then squirm their way in via some swivel joints and making sure they have someone with small hands to reach in there. It isn't a fun job for sure and most places charge you 150 -200 Dollars to change the thermostat on a 1.8 which is crazy. I rather change it myself and go out and have a nice steak afterwards and still have money left over.
That said, on the 2.0 cars it takes about 15 minutes or less to change the thermostat. Easy access and virtually painless.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
flashing red coolant light shellbug 2.5 Liter Gas 34 06-20-2014 05:33 PM
Blue Coolant light flashing..... GOBUGWILD 2.0 Liter Gas 8 08-06-2011 03:40 AM
Flashing Blue Coolant Light Fl_bug 1.8 Liter Turbo 16 10-16-2010 09:54 PM
Coolant/Flashing red temp light scooter Questions, Issues, Concerns, or Problems with the New Beetle 7 07-30-2008 01:54 PM
Blue coolant light flashing? DruzeTito 1.8 Liter Turbo 7 04-19-2006 12:12 AM
