Mass Air Flow sensor - NewBeetle.org Forums
Old 04-29-2012, 04:55 AM
Default Mass Air Flow sensor
Can a mass air flow sensor make your car lose power when you push the gas pedal all the way down it flutters like its gonna die and will not rive up stays at about 3 rpm sounds awful i took off the sensor and it rived up just fine does that let me know thats the problem? the plug-in that the air flow sensor plugs into the red part inside is dry rotted can you get a new plug? and where could i find one i have been looking every where on the internet i hope its just the air flow sensor thats bad would the o2 sensor cause this problem also?
Old 04-29-2012, 04:01 PM
Garage
Try cleaning the MAF first and see if it helps.
Old 04-29-2012, 05:49 PM
I did it didn't help
Old 04-29-2012, 06:03 PM
IndyTom's Avatar
Indianapolis, IN, USA
Car: 2012 Tornado Red VW Beetle Tsi
First thing I would do is get your car scanned for codes to see what we are dealing with. You can spend a lot of money guessing what it "Might" be without actually ever fixing your problem.
Also what type of engine and transmission do you have?
Did you check for vacuum leaks? Replace any old rubber hoses?
Old 04-29-2012, 06:11 PM
IndyTom's Avatar
Here are some links on MAF connector replacements.
How-to: MAF Connector Replacement
MAF Sensor plug
How to Replace Broken Wire Harness Clips/Connectors Audi/VW DIY
You can try and disconnect the MAF and see if it improves your issue. Check for vacuum leaks.
Old 04-29-2012, 10:04 PM
ok just figured that might be the problem since it does better with the MAF out my bug is a 2000 gls with a 2.0
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
mass air flow sensor pepino68 1.8 Liter Turbo 2 12-23-2010 03:52 AM
Mass Air Flow Sensor fxn351@aol.com 1.9 Liter TDI 6 06-23-2009 08:30 PM
Mass Air Flow Sensor andrzejvan 1.8 Liter Turbo 5 04-05-2009 02:44 AM
mass air flow sensor? bobwb 1.8 Liter Turbo 14 12-17-2007 11:31 PM
FS: 2.0 mass air flow sensor B-Power-B Market Place Archives 1 10-19-2005 10:15 PM
