Unlearn a remote fob - NewBeetle.org Forums
Old 11-29-2012, 03:53 AM
Australia
Default Unlearn a remote fob
So I did something silly today.
I have two Beetles with different remote styles (rounded buttons one and the more common vw square one).
I decided to see if I could get the older car to use the newer style remote off the other car. Yes it works! Old car had no problem learning the new remote.
But now I have a remote that can unlock both cars. I only want it to unlock one car. How do I "unlearn" the remote fob from one car?
Old 11-29-2012, 01:25 PM
Knoxville, TN,
You might find this useful:
mk4 and B5 Remote Learning with VCDS by Ross Tech - YouTube
Adaptation 00 will clear all remotes.
If you have manual crank windows, then you would scan address 35 Central Locking instead of 46, but still go into Adaptation channel 00 to clear learned remote values.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 11-29-2012, 02:32 PM
Australia
Thank you!
Hopefully that does the trick. It's really annoying when I unlock both cars at the same time.
Old 11-30-2012, 01:21 AM
Knoxville, TN,
I've got 3 cars on the same key and remote. It is great, I always have the correct key when I go out.
If you disarm the alarm (unlock doors with remote), but don't open up the car, the alarm will rearm and lock the doors after 1 minute.
The remote has no clue about anything.... you could set up 1 remote to lock/unlock 100 cars at the same time, remote don't care.
Old 12-01-2012, 08:22 AM
hello mate.. i'm a newbie! i think thats a pretty annoying situation.. why dont you try doing this following steps i found for your key fobs..
Remote control erasing
1997 or later
Switch ignition on and leave the key in the ignition
Lock the vehicle by using a manual key from driver’s door
Press he remote control lock button 5 times within 1 second intervals. The horn should sound or the indicators flash
After 6 seconds press the unlock button once to activate memory erase
Switch ignition off
i hope it works and helps! if not try going to the page and see more here Volkswagen
cheers mates!
remote key Globervw 2.0 Liter Gas 0 10-26-2011 04:30 PM
key remote awaynot Questions, Issues, Concerns, or Problems with the New Beetle 4 07-18-2009 04:21 AM
WTB: Key Remote jakthree Parts and Accessories 2 04-08-2009 05:10 PM
Opening the hatchback with the remote. And another thing about the remote. Mike Hunt Questions, Issues, Concerns, or Problems with the New Beetle 4 04-03-2009 08:28 PM
WTB: remote for key beetler4cer Market Place Archives 8 05-12-2006 06:36 PM
