2000 V'dub questions - NewBeetle.org Forums
Old 12-05-2012, 07:24 PM
Skeeter
B.C., Canada
Car: 2000 VW Beetle & 76 Westie
Default 2000 V'dub questions
Hi...
I have a 2000 Beetle, have owned it since 2002. It has 225,000 km. Mostly highway miles. I have maintained this car very well, regular oil changes (synthetic oil), timing belt at 100,000 & 200,000, cv joint replaced, among other small things like brake lines etc.
There is clunking sound at the front when I hit bumps (mechanic said it was the front struts) and will need the brake routers resurfaced soon.
So my question is: is there anything else that I should do so I can drive the car from BC to Quebec next summer? I try to be ahead of problems (and breakdowns), before they surface. AND my brother is the mechanic - need to have all the service done before I head east!!
And can I tow a small trailer (flat) - what is the max weight?
Thanks for any advice...
Cheers!
Old 12-05-2012, 09:14 PM
IndyTom's Avatar
Indianapolis, IN, USA
The front clunking sound are the Front Sway bar bushings.
Very common especially if they have never been replaced.
I had the same problem and after swapping out the bushings there were no more clunks. Took me about 30 minutes per side and they cost about 10 dollars a piece. Very easy fix.
Here is a link to a DIY. Too bad the OP is no longer active and the pictures were removed. But it really is a very easy job to do and the first thing I have ever done to my Beetle.
DIY: Sway Bar Bushing Replacement
Here is a complete kit that comes with new brackets and new bolts which is nice to have. Also you either have 21mm or 23mm front sway bar. Mine is a 2000 and had a 23mm Front Sway bar.
Volkswagen New Beetle 1.8T > Search > Sway Bar Bushings > ES#259396 Front Sway Bar Installation Kit - 1J0698336D
2000 V'dub Beetle Skeeter2000 New Member Forum 3 12-09-2012 11:05 PM
Automatic 2000 transmission questions SweetPeamywonderbug Transmission Talk 5 08-31-2011 01:31 AM
2000 GLX 1.8 T questions TheBrain 1.8 Liter Turbo 11 12-28-2007 03:19 PM
Questions about my 2000 New beetle endlsskys 2.0 Liter Gas 3 08-20-2007 02:39 AM
Some questions for the 2000 2.0L Bug Frapp 2.0 Liter Gas 13 11-07-2006 02:36 AM
