Maf - NewBeetle.org Forums
Old 03-23-2006, 06:12 PM
rob11g's Avatar
NJ, USA
Car: 1998 Beelte 2.0L
Question Maf
I read that the MAF would cause my 98 Beetle to lose power and give me a hard time starting. These are the exact simptoms the car is having now. The check engine light is also on. What causes the MAF to go bad ? Is there something I should be doing to extend its life cycle ?
Old 03-23-2006, 07:18 PM
noR's Avatar
Administrator
Jackson, MS, USA
You could try cleaning it. Put it in a baggy w/some isopropyl alcohol. Or use some electrical contact cleaner.
You could unplug it and see if your starting/loss of power symptoms go away. Yes it'll cause CEL's, but this is a diagnostic proceedure, not a solution. If that fixes it try to fix the sensor; but most likely you'll need to blow $50 on the sensor.
noR | me | Phrog
PHROG
Old 03-23-2006, 07:20 PM
iScott's Avatar
Die with your boots on
Atlanta, GA, USA
Car: Noir'a, black '98 2.0
What is the MAF? I ask because I've had slight trouble starting; well, just a noise, really, that happens when it's cold. But it's still something I'd like to check. I'll refer to the Bentley.
Floored
Old 03-23-2006, 11:25 PM
rob11g's Avatar
NJ, USA
When I unpluged it the engine seemed to run a little wierd, I can drive the car without it being plugged in ?? Your saying I can just replace the sensor in the MAF ? I priced a new MAF and it costs over $200 dollars.
Old 03-25-2006, 11:49 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
Try here: http://www.worldimpex.com/item_detail.html?sku=8395 Only $77.73. (800) 736-3550
Old 03-25-2006, 11:56 AM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
Guys, remember that VW extended the warranty on the MAF to 80,000 miles because of all the faulty units. If they scan it and it throws a MAF related code,it will be replaced at no charge to you.
(\__/)
(")_(")
Me: www.myspace.com/beetlenut
