heater a/c blower fan. - NewBeetle.org Forums
Old 03-29-2006, 11:23 PM
Default heater a/c blower fan.
My heater a/c fan is just about toast I think.
I turn it on, and it seems to work OK, although it does not put out as much air as I think it should. After a while, it seems to slow down a bit, and from time to time it makes a rumbling noise. If I have the radio on a low AM frequency, the fan introduces a lot of noise to the radio. And sometimes the fan just stops after a few minutes. Turn the fan off, and back on a few minutes later, and it works again.
Does this sound like the fan motor? Does anyone have any idea how to replace that fan motor?
Thanks, Mathew Banack
Old 03-29-2006, 11:36 PM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
paraphrased from Bentley manual:
*: open pass. door
*: pry off rt. sid etrim panel
*: remove glove box mounting screw
*: Pry off (2) switch console covers (where emer. flasher/ def. switch are)
*: remove (4) mounting screws
*: pull switch console down from bracket
*: remove the glovebox retaining screws (6) and glove box
*: disconnect harness connector for glove box light.
*: remove screws (4) and cover
*: remove lower cover containing series connector pack and disconnect harness connector
*: disconnect harness connector from blower fan
*: pull blower fan out and downward.
------------------------end---------------------------
Old 03-30-2006, 11:58 AM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
Here is something to consider: When was the last time you changed your cabin air filter? If you've got a clogged filter, it is going to put more stress on the fan and it won't blow as much air.
I don't think this is the problem you're having, but its good maintenance anyway.
"The rich ruleth over the poor, and the borrower is servant to the lender."
Proverbs 22:7
Old 03-30-2006, 03:08 PM
Default Thanks all
When I take it apart and fix it I will post my findings.
Old 12-16-2008, 11:10 PM
where is the cabin air filter that you are talking about? thanks
in line heater electraglide The Canada Corner 7 02-07-2012 01:49 AM
Fan Control #1 _twistedmind_ 2.0 Liter Gas 1 12-19-2005 07:29 AM
Block heater? brittanyalysson Questions, Issues, Concerns, or Problems with the New Beetle 4 11-17-2005 07:08 PM
Block Heater? brittanyalysson 1.9 Liter TDI 2 11-17-2005 03:10 AM
Fan on fan off prudence Questions, Issues, Concerns, or Problems with the New Beetle 0 10-09-2005 11:15 PM
