I have never heard of routine cleaning of the MAF. Do you mean throttle body?
I had to clean the MAF on another car because it was throwing a CEL - possibly caused by running a K&N. If you do mean the MAF, just pull the sensor out of the tube and spray it with non-residue contact cleaner. Your may need a security torx bit to remove it. I was thinking of cleaning the TB on our car but that stupid hose is freakin' hard to get off. b |
i plan on cleaning my MAF this summer when i clean my air filter. the easiest way i've seen to clean it is, once it's off, leave it in a bag of isopropyl alcohol for a few minutes, then swish it around top dislodge whatever gunk is in/on it, then take it out and leave it dry completely.
as far as taking it off, it's bolted to the top half of the airbox (the airbox cover if you will). i plan on disconnecting the hose leading to it, then the electrical connection to the MAF, then loosen the tabs around the cover and the (i think) 2-ish screws holding it in, then pulling the whole thing out. they say the 2 screws holding it to the cover don't fit any driver they've tried, but i trust you can figure out how best to creatively remove them. (as will I.) just don't forget that you need to resuse both the screws and the holes. ![]() tell us how it goes!
Vise grips work well!
"How To" Clean your MAF Items needed. 90% or stronger Isopropyl Alcohol, 1 Gallon Ziploc baggy, Phillips head screw driver, 10mm socket and 6" extension. 1) Undo Clamp from the left side of the MAF and unplug. 2) Remove air box with MAF attached. 3) Unbolt MAF 4) Pour 1 bottle of 90% or stronger Isopropyl Alcohol (rubbing alcohol) into a 1 gallon Ziploc baggy. 5) Drop in MAF 6) Swish around for a few minutes. 7) Remove from baggy and allow to dry for 15 minutes 8) Reinstall. As Always Do This At Your Own Risk |
thanks! |
![]() Those fasteners have what's called security torx heads. You can find a security torx bit at a tool store. Look in the yellow pages. You don't really need to soak the sensor - just spray it good with non-residue electronics cleaner. And be careful not to damage it - sloshing may not be a good idea. b |
First, here is my problem. Starts up on a cold start and runs perfectly. Turn off and re-start while hot, within 20-30 minutes, it idles rough and the brake pedal is hard to push in. It will fix itself each time, no CEL. It comes and goes. Just so I don't clean this wrong, it's the MAF hose and not the sensor, right? Any other thoughts? Thanks in advance.
Later, Rich |
I was at Murrays the other day and noticed that CRC now makes an actual MAF cleaner. So this must be an issue across the board and not just on dubs.
I bought some. Sprayed it in and it cleaned it right up. Dried instantly. Seems like good stuff and not a bad deal for $5 a can. Should be able to clean your MAF a dozen times or so. |
Actually, that was replaced by the stealer after me banging my head around under the hood for about a week. I tried everything I could think of before I took it, but they diagnosed it immediately, Doh! I wish there was a "ask a nurse" phone line for beetle owners, because sometimes the symptoms are so darned random. In this case I had a bad brake booster hose, bad o2 sensor, and bad fuel pump regulator. I fixed 2 out of the 3, but that vacuum leak was throwing all kinds of wacky codes.
I imagine it's a pretty easy fix, you'll just have to remove the airbox to get to it, loosen a couple of clamps, and you are home free. Good luck! |
| Cleaning MAF | rob11g | 2.0 Liter Gas | 3 | 03-18-2006 01:55 AM |
| Cleaning Leatherette | suzyq2463 | New Beetle Detailing/Cleaning | 9 | 03-06-2006 01:54 AM |
| Intercooler cleaning | jibeho | 1.9 Liter TDI | 7 | 01-28-2006 10:43 PM |
| Cleaning up... | VelvetFoot | Market Place Archives | 0 | 10-30-2005 04:47 PM |
