Help !! a/c not working Any gurus ?? - NewBeetle.org Forums
Old 04-13-2006, 12:57 PM
Columbia , SC,
Car: 2000 tdi
Default Help !! a/c not working Any gurus ??
My wifes car, 2000 NB tdi
I have just replaced my cooling fans as the a/c would not engage.
Now the compressor engages so the cooling fan module is working.
I have the wrong pressure in my a/c.
The pressure is showing 90 psi in both high and low circuits before switching on. I dont think freon is low.
With the compressor running, I am seeing 85 psi low and 100 psi high. I would be expecting 45-50 low 250 high.
The system has never been opened and it was working fine last fall.
Where should I start looking for the problem?
thanks
Old 04-13-2006, 01:15 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
Here is our local guru - maybe you can email him and bounce that off of him...
http://www.dfwnbclub.org/forum/phpBB...pic.php?t=2264
marvins_dad ~ antoine
Old 04-13-2006, 08:01 PM
I am not a guru but have repaired A/C systems before! If the pressure remains high it can be one of two things: Compressor is bad or the orifice is bad. My thought is that the compressor is failing. I think it is worth taking it to an A/C repair place and ask for a professional check up. It should not cost a lot and might point you in a cheaper direction.
I'm new and I'm working on pictures bockegg New Member Forum 10 04-13-2006 11:57 PM
Photoshop gurus - need help! my99vdub Miscellaneous Hoo-Ha Archive 5 03-24-2006 12:07 PM
New to the site and working on beetle's Nymphonic13 New Member Forum 6 03-22-2006 03:35 PM
Question for the Mac gurus my99vdub Miscellaneous Hoo-Ha Archive 14 12-18-2005 11:51 AM
