All those lights and beeps!! Help!! - NewBeetle.org Forums
Old 04-27-2006, 04:27 PM
Default All those lights and beeps!! Help!!
My 2000 Turbo has the following lights on constantly on the dash, EPC, ABS, BRAKE, and a few more I can't remember. They came on during an A/C charge. The BRAKE light flashes and beeps all the time - very annoying. It stops beeping when I put my foot on the brake and stop. How do I turn them off?
Old 04-27-2006, 05:12 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
Gotta scan/reset them with a VAGCOM Tool. Dealers/someone local to your area in the HOW-TO VAGCOM Sharing thread can do this for you. The ABS/Brake means an ABS failure of some kind, not so sure about the EPC.
Old 04-29-2006, 11:29 AM
KansasDiesel's Avatar
Just Bugged
KS, USA
Car: 2001 and 2002 New Beetle GSL TDI
I suggested just that on her last post she had the same problem. even said I would help with my vag-com if she was in my area.
My car "Gus" Gray 2002 NB GSL TDI has everything even leather and sunroof
MY wifes car "Daisy" a Yellow 2001 NB GSL TDI everything but leather and sunroof.best mpg 53 and 805 miles in one tank
Truck Black Ford F350 Powerstroke Diesel (of course),CC,dully, 350hp+ running on WVO!
Old 06-18-2006, 12:50 AM
I am having more or less the same problem on my sisters beetle. I was working on the AC which no longer works, I think the compressor went bad. A friend of mine said to look at the High pressure relay switch after I did that the car started with both the EPC and the brake light on permanatly. The car doesn't start beeping until it goes over roughly 10mph. Is this VAGCOM tool the answer. If so how hard is it to scan reset. Also KansasDeisel were are you from in Kansas, I'm in Olathe.
Thanks
Adam
Old 06-20-2006, 05:16 PM
Just Bugged
KS, USA
Thanks
Adam
Your close, I work in Olathe and live past the raceway.
It's easy to scan and easy to reset.
Old 06-20-2006, 05:25 PM
Just Bugged
KS, USA
Thanks
Adam
Adam
Check your PM's
Old 06-21-2006, 08:55 AM
GREECE,
Car: 1,6 -May 2000
take care with this problem my friend because i've got the same one and i had an accident....it wasn't for me a simple vag com reset but ESP Unit...here in Europe about 1000$....!
Old 06-21-2006, 05:27 PM
Just Bugged
KS, USA
I just don't reset if there is a problem. If he contacts me we will first see if there are any codes and if I can't figure out the problem with that I will be on here or TDI Club, trying to find the answer.... Thanks for the concern
Old 06-21-2006, 07:40 PM
Smile
dont be a troll.. look at me.. I'm a troll... dont be a troll...
Admin edit: Running outta things to say...
Old 06-21-2006, 07:49 PM
scoester's Avatar
Finally got a new Beetle!
Nampa, ID, USA
Car: '99 Silver GLX
Does anybody have a spare trunk monkey we can let loose on this guy.
lights out slugbug123 Questions, Issues, Concerns, or Problems with the New Beetle 11 12-03-2010 02:49 AM
Brake Lights funky 1.8 Liter Turbo 6 12-23-2005 04:03 PM
Fog lights mlegions Styling Modifications 1 11-16-2005 08:09 PM
No dash lights Don_n_Herbie Questions, Issues, Concerns, or Problems with the New Beetle 8 10-30-2005 06:01 PM
LED lights. dgoldbe2 Styling Modifications 11 10-17-2005 04:30 PM
