cd stuck in cd player? - NewBeetle.org Forums
Old 05-01-2006, 07:50 PM
Chubs763's Avatar
Brooklyn Park, MN, USA
Car: '04 NBC GL - Aqua Blue
Default cd stuck in cd player?
so today may 1 is the day the NBC gets to come out of the garage after a 6 month sleep.
i went to pop in a cd and it wouldn't take it. it's making a horrible grinding noise. now i can't remember if i left a cd in there over the winter.
so my question is, if a cd is stuck in the VW supplied player, how can a person pry it out? i assume if the player is actually empty, i can get a warranty replacement.
thanks!
Old 05-01-2006, 08:57 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
VW should be responsible for loss or damage of the disc; so they should replace the unit and replace/return the original CD... I'd think, at least. Call VWoA.
Old 05-10-2006, 01:11 AM
mezonesxbox's Avatar
Beetle maniac
Newport Beach, CA, USA
Car: New Beetle 2000 GLS, Audi A6 2000
I took my Cd player out when that happened and poped the CD out. This is fairly common on all CD players. Its not too hard, but you need the special radio tool to take it out.
Old 05-10-2006, 03:46 PM
Steinola's Avatar
Portland, OR, USA
Isn't there a little "emergency extraction hole" on the face of the OEM deck? All CD players should have 'em... but I've never actually checked the VW headunit for one. Should be a pin-sized hole under the lower left corner of the CD slot.
If there is a hole, you stick an unbent paperclip in... and it manually pushes the CD eject mechanism. If there's a CD in the deck, that should pop it out. If nothing comes out, it means the player is most likely empty. If there's no CD in it, and it's still making a grinding noise, I'd imagine a replacement would be in order... but it all depends on what's still under warranty.
Old 05-10-2006, 04:40 PM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
Try a popsicle stick into the slot. If you feel resistance, CD. If none...
Hell, sometimes I use the slot as a holder for my Bluetooth headset.
-Des
Previously:
Old 06-12-2006, 04:44 PM
Chubs763's Avatar
Thanks everyone. VW replaced the cd player under warranty. they scratched the centre console a wee bit, but can't make an omlette, etc. i'm just happy it works again.
What have you seen stuck in traffic? EvilinaDM101 Miscellaneous Hoo-Ha Archive 46 07-22-2006 09:28 PM
Removing Headlight - it's stuck sleds4ever Questions, Issues, Concerns, or Problems with the New Beetle 2 04-08-2006 07:54 PM
Stuck on a desert island Toad Miscellaneous Hoo-Ha Archive 30 10-01-2005 11:37 PM
