Brake Light Switch - NewBeetle.org Forums
Old 05-19-2006, 09:28 PM
larryziegler's Avatar
Clovis, CA, USA
Car: Ex 1999 Beetle GLS Owner/2005 Honda Pilot/2008 Acura TSX
Default Brake Light Switch
My wife informed me that she couldn't get the Beetle out of park this morning. Having replaced the brake light switch exactly 1 year ago, I knew what the problem was. I called Clovis VW and picked up the part for $15.85 + tax (the parts person gave me extreme warnings about breaking the part, which has been addressed in Eeyore's how-to and the Vortex how-to. At lunch, I removed the part, and using it as the ghuinea pig for proper replacement and using Eeyore's method of adjustment for this part, I followed all the directions in hooking it back up...VOILA....the old part now worked again.....at first with the brake lights on all the time, then properly after a re-adjustment of the spring loaded pin. For how long, I don't know. Before I replaced it, it was working intermittently, so after replacing it, I decided to drive it back to work and have had abssolutly no problems with it. It takes longer to remove/replace the 3 screws for the underdash panel than it does to replace the part itself. Now I have a spare part (the dealer won't make refunds on this part), but for $17, it was all worth it, especially having the piece of mind of the new part there, in case I broke the old one.
Old 05-24-2006, 01:52 PM
bman's Avatar
Saint Catharines, Ontario, Canada
Car: 2000 GLX
Glad it worked out for you. I always am happy that I can drive my car (a manual tranny) without regard for whether or not the brake light switch is working... wouldn't want to be stranded after all!
But the more I think on it, it would be nice to know when that switch was in fact faulty - it's hard for me to activate the brake lights and see if they're working or not without a vehicle or wall behind me at night, or someone else helping me out otherwise...
Old 05-24-2006, 02:23 PM
jpdeuce's Avatar
Diesel Inside
Frisco, TX, USA
Car: 06 Jetta TDI
Do you have links to those guides on how not the break the part and how to adjust it?
Old 05-24-2006, 02:43 PM
Clovis, CA, USA
http://forums.newbeetle.org/showthre...threadid=32064
http://forums.vwvortex.com/zerothread?id=1158315
Part #191-945-515-E
The most current part number shown now has the suffix E at the end. Your old part will have something between A-D.
Both of these threads had very useful info to use.
Brake Switch Replace - How-To marvins_dad Technical How-To 1 09-20-2006 01:48 PM
brake light switch atticus Questions, Issues, Concerns, or Problems with the New Beetle 7 05-13-2006 10:32 PM
Brake Light Switch brwnidgrl New Beetle Convertible 2 04-20-2006 04:38 PM
What's with the stupid brake light switch.. rcy Questions, Issues, Concerns, or Problems with the New Beetle 5 02-25-2006 04:48 PM
brake light switch recall...? manoverboard987 Questions, Issues, Concerns, or Problems with the New Beetle 3 11-14-2005 04:12 PM
