Justin,
Gotta go fire up the BBQ, but I've got a minute. I'm looking at my printed version of the Bentley. On page 19-16, it shows a 4-pin harness that plugs onto the coolant temp sensor ( or a 2-pin for the AEG engine with A/C only). It also warns to release the cooling system pressure before removing it.
All (he is) saying...is give (war) a chance... [apologies to John Lennon] "Nibblin' on spongecake, watchin' the sun bake, all of those tourists covered in oil..." "Your Freudian slip is showing..." "Reality is just that surreal time between my dreams" - me |
Thanks Alan!
![]() I'll have to go look again, but I don't think the thing I was looking at had 4 wires. I do remember two contacts, or sockets, but not 4 wires. Hmmmm. I'm thinking the stealership is going to get it on monday. ![]() |
Get the breather hose (the ribbed hose that goes to the airbox, your question makr is right on it) out of the way and you'll spot it underneath.
At the angle of you pic, it's just a litte above the question mark underneath that hose. It sits upright and you'll spot it because it's just about the only thing there with an electronic connector. Make sure you do this when the car is cold.
2001.5 NB GLX AWV 02J LG5T 08H/ZD, with modifications |
Thank you Paul!
I attached a pic to verify that I am looking at the right thing, correct? I got to thinking, after opening the hood, there seemed to be a irregular amount of heat coming from the engine. This tells me that the engine is quite hot, which means to me that the sensor is probably fine as it let me know the engine was hot. If my thoughts are on track and the sensor is working, then the next step should be the thermostat, right? Can someone point it out to me? I hate being this "dumb" when it comes to my own car. (Give me a schematic and an airplane and I could rewire the whole thing, no problem. But ask me to find a manifold on my own car? I can't even guess.) |
The thermostat is just beside the rear of the alternator. You will see the hose coming out of the cover for the thermostat. It looks possible to get it out without removing the alternator, but I have not changed one so I can't say for sure if you have to remove the alternator or not. Might be easier to change with the alternator out of the way.
you got the Temp sensor correct. its an easy fix but as paul said keep it cold.
the thermostat is a bitch. its next to the alternator and under the manifold. it sounds like you may need your timing belt done. these are the exact symptoms i had. how many miles?
oneighturbo.com | flickr | XBL: oneighturbo | beaman GIAC | O.Z | TOYO | KONI | EIBACH | GHL | VF ENGINEERING | O-Bar | FORGE | and of course VW |
Thanks for the reply Corey!
![]() Mileage is sitting at 48170 at this very moment. From what I have read here on the Org, there isn't any way to tell if the Waterpump went bad, other than overheating, right? I'm gonna have the wife call the dealer tomorrow and see if they can squeeze it in to take a look. If it is the waterpump, that should be covered under warranty. I'll have them do the timing belt if the need to tear into it. ![]() (Why isn't there anyone with VAG-COM near? I guess I should buy one, eh?) ![]() |
How much would a ton be? I wonder what size container I'll need to use to catch all the G12, instead of letting it run across the parking lot. |
Thanks Justin!
I just got back from taking it to the dealer. It's under warranty, so I might as well make use of it while I can. They are going to diagnose the problem and call me this afternoon. I may not know much about the workings of a car, but something tells me that if the water pump isn't circulating the coolant around the system, then I probably am not going to have coolant moving through the heater core, thus a failure of the water pump would explain the lack of heat coming out of the vents on the way to the dealer. (WOW! That was a run-on sentence if I ever saw one! My english teacher should be proud!) Am I correct in this assumption? |
these things have a mind of their own. mine went at 40k. im not sure if a VAG-COM could have helped but it is a def buy!!!! |
The dealer just called and said it was a ECT, Engine Coolant Temp sensor. I'm not thinking it's right, but that is what codes were thrown. I'll put it through it's paces tonight and find out.
Thanks everyone! ![]() |
Bad temp sensor would be a constant blue light. You'll be back at the dealer soon enough as crappy as that sounds.
j. i know you dont need this but if anyone else reads this and needs a kit...
http://forums.vwvortex.com/zerothread?id=2618678 |
Well, I just got home from the dealer......without the TS. We took it down the highway after picking it up, and sure enough the red temp light started flashing again.
So we took it back and they were "Surprised" by it coming back. They did say it popped a P0117 code, which I haven't looked to see what that is yet. They R&R'd the ECT sensor and "road checked" it. I looked at the mileage when I dropped it off, and when I got in it this afternoon, there wasn't even a full mile on it. I don't know how they got it hot enough to make sure that it wasn't overheating again. I had to drive it amost 6 miles to get it to come on. Just proves what most of us believe about MOST dealership mechanics.....they are freakin' idiots! If it does come up that it is a water pump that came apart, I think I might have a word with the GM about the "Service" or lack thereof. ![]() |
The dealership just called, and said they replaced the Thermostat, and the water pump impeller was shattered. They didn't even call me to let me know that they were replacing the water pump. I'm a bit mad at that. I was going to have them do a timing belt at the same time, even though she said the timing belt is good until 105k.
They probably did it on purpose just to get more money out of me. ![]() |
| overheating after replacing fitting | dudeare | 2.0 Liter Gas | 1 | 05-07-2006 11:19 PM |
| Overheating Problem | palomba16 | 2.0 Liter Gas | 10 | 02-24-2006 02:18 AM |
| 2000 Beetle overheating??????? HELP | stevebug | Questions, Issues, Concerns, or Problems with the New Beetle | 12 | 01-16-2006 09:30 PM |
| Temp light & Overheating | Oddball | 2.0 Liter Gas | 2 | 11-16-2005 03:43 PM |
