| Paint and Body The place to discuss paint and body related problems, modifications and custom ideas pertaining to the New Beetle. |
SoCalnewbeetleclub |
What did you paint it with? Looks nice
CLICK-- Cup- my New Beetle Org members Facebook group: "The Collective" CLICK HERE |
Color: flat black
Method: spray can (used one of those sprayer handle attachments which REALLY helped it lay down nice and even). Dry sanded through the coating then wet sanded the rest. 2 coats of primer sanded in between followed by 3 flat top coats. Sent from my iPhone using Autoguide.com App |
I'll post more detailed pics on the vent and radio surround. Needs it BAAAD!
Got some plastic razors at ACE for under $2. Beats sanding x10. Followed with rubbing alcohol and scotch brite pad and 400 grit wet sand. Primed and ready for paint and flat sealer!
![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Autoguide.com App |
Do NOT use flat enamel sealer! Fortunately I tried it out on a small item beforehand. Scraped off just like the factory coating :-/
SO you ended up not using the flat enamel clearcoat?
What did you use to protect the paint? Are you keeping the paint flat? I was wondering if the flat surface scratches more than a glossy surface. Thanks for the tips on the project! |
@PRM Easy stuff as long as the temps and humidity are good.
Sent from my iPhone using AutoGuide.com App |
I just took the center panel off, the one with all the stuff. Used Scotch Brite pads and then some 600 grit wet dry. Used some stuff like Armour All to get to a semi-gloss look. BUT yours looks nicer!!
Retired in Iowa. 2000 NB 1.9L Turbo Diesel TDI Too many hobbies, not enough time. |
Thanks for the tips on prepping the surfaces. Yours came out great. I've been thinking about painting mine the same color as is on the car, platinum gray.
I've had the forward most dash panel off before when I replaced my cabin filter. How are the other pieces to remove? I'm thinking about doing the grab handle end pieces, vase holder & other piece on the drivers side (is there a name for it, LOL?). How are they removed? Thanks, and again, nice work
2005 NB TDI 5-Speed-->Sluggo |
Present: 2012 Beetle Turbo Past: 2002 NB Sport 2001 NB TDI Way Past: 1981 Scirocco S, 1983 Scirocco Wolfsburg Edition, 1985 Quantum Wolfsburg Edition Visit here too: https://www.facebook.com/groups/407758410320/ https://www.facebook.com/NorthCarolinaBeetleGroup |
| 99 GLS project car | 99bugman | New Member Forum | 3 | 08-29-2012 12:55 AM |
| Centre dash section complete with Audi TT dash vents installed | pyro | Parts and Accessories | 2 | 10-20-2009 10:12 AM |
| WTB: Center dash pieces, dash panel covers | silverspeedbuggy | Parts and Accessories | 4 | 05-08-2008 01:55 PM |
| New with Project '98 | WOB_Beetle | New Member Forum | 4 | 09-25-2007 05:58 AM |
| The age project | Celeste | Miscellaneous Hoo-Ha Archive | 12 | 07-08-2007 12:33 PM |
