| Technical Modifications The place to discuss technical and performance related modifications for the New Beetle. |
OK, so in the next few months I'm building my own set of HID's.. My question is, it appears any shroud available would leave a huge, gaping space around where the stock projector is.. and I don't want a huge, bulky shroud just to take up space.
I played around with the idea of just replacing the stock halogen projector with the HID one I'm looking at, but the one I want is bi-xenon. So I don't need the halogen high beam below. How would I go about having a custom shroud made? Or should I just leave the halogen high beam there and not use it?
Join us on the Talimena Drive, Fall of 2013! All the details here! Quote:
I have a euro-switch with disabled DRL's as well, only issue is that since using my fogs more frequently, the wire coming off the ignition switch to the load reduction relay is turning really brown... I think I need to rewire the fogs to somewhere else before it fries my ignition switch. Oh, which reminds me.. WIRING. I can't seem to find a decent answer.. I've had a brand new headlight in for maybe a year (DRL's disabled since about 4 years ago) and when I went to put the drop in HID kit in, I discovered the coating is ALREADY falling off the wires.. For this retrofit, I'm getting 2 brand new headlights and I do not want this to happen. Are HID's harder on the harness, because obviously halogens are doing a number on it. What would be a possible solution to this? Maybe piece together my own harness with a thicker wire? What can I do to keep the stupid thing from frying? |
I really wish they made glass housing e-codes for the NB. I have a set on my GTI and I freaking love 'em. Light pattern is different and the lighting is just all around better.
And I have to say that just because you haven't been flashed by oncoming traffic doesn't mean much. I'm usually blinded by HIDs when someone is behind me and its hard to flash your highbeams at them then ![]()
The Past Ride: Darla, 102k, '99 New Beetle GL 5-speed. Bone stock. Acquired 4/6/05. Gave her life for me 8/17/11. RIP ![]() The Project: Klaus, 180k+, '84 Jetta GL Turbo Diesel. Rebuilt and bringing 50+ mpg. Slightly improved from stock Acquired 7/12/08The Baby Brother: Günther, 120k, 20th Anniversary Edition GTI ![]() The money saver:2001 Jetta TDI GL. 117k. Dead auto, swapped to 3 pedals. Hubby's DD and our trip car |
Hmm, I don't have any of these issues with my wiring. I know that over time wiring can build up resistance which can heat it up more than usual. But it shouldn't turn wires brown or melt them.
What wattage bulbs are you running in you fogs? About my Hid pattern, it looks great and offers much more visibility than the stock bulbs. The stock projectors work just fine. Also the Hid!s run at lower voltage than the stock halogens. Visibility drops if you use 6000k bulbs or higher. The light will turn blue then purple and the higher the range (6000, 8000,10000 etc). The brightest whitest bulbs are 4500k. I wouldn't use anything over 5000k. After 6000k it just looks ghetto. |
All I'm saying is I want a very even light distribution with a razor sharp cut off. There's no way I'd get that from the stock projectors.
I've decided to go bi-xenon. Which will not utilize any of the stock wiring so that is not longer a concern. I wanna go with 4300k too. I use regular ole H1 bulbs in my fogs. Nothing special. Have you actually taken your panel off and looked at your ignition switch wiring? I replaced my ignition switch over a year ago and never put the panel back on because I was lazy. The wired looked totally normal. I never used my fog lights until a few months ago because one was burnt out and I felt stupid using one. Now I use them semi-frequently, and the wire has started turning brown. I can see it because I never put that panel back on lol. I remember hearing its a common problem, the fogs draw too much for VW's inadequate stock wiring. The solution seems to be re-wiring the fogs to another power source. I wish the beetles had e codes too. ![]() |
| HID Retrofit Questions | Connelly | Technical Modifications | 4 | 11-30-2012 12:30 PM |
| FS: HID Retrofit kit, used | kcfoxie | Parts and Accessories | 6 | 05-27-2011 11:55 AM |
| Retrofit Question | Fl_bug | Questions, Issues, Concerns, or Problems with the New Beetle | 9 | 10-25-2010 04:08 AM |
| 06-10 Bumper Retrofit? | Bugs_4_ever | Styling Modifications | 3 | 07-15-2010 11:48 PM |
