| 1.8 Liter Turbo Discussion area for the 1.8 liter turbocharged engine. |
G12+ is the new stuff. I think its purple vs the pink of g12 but they should all be compatible.
Sent from my SCH-I405 using AutoGuide.Com Free App
The Past Ride: Darla, 102k, '99 New Beetle GL 5-speed. Bone stock. Acquired 4/6/05. Gave her life for me 8/17/11. RIP ![]() The Project: Klaus, 180k+, '84 Jetta GL Turbo Diesel. Rebuilt and bringing 50+ mpg. Slightly improved from stock Acquired 7/12/08The Baby Brother: Günther, 120k, 20th Anniversary Edition GTI ![]() The money saver:2001 Jetta TDI GL. 117k. Dead auto, swapped to 3 pedals. Hubby's DD and our trip car |
G12+ can be mixed with G12. It is my understanding the G12+ is mainly from Audi to address heater core issues (the B5 Passats also have the same problem). Those heater cores get clogged up with "sand", mineral deposits or whatever. Beetles don't have this issue, so there unless G12+ is cheaper, there is no need to use it.
Pencilneck blah blah blah OEM Wheel Database.... http://www.4130-products.com/wheels 5052 @ $8000 = total crap VAG COM @ $350 = sanity |
VW dealers do?
I would never use anything other than G12/G12+/G12++ unless I did a very, very thorough flush. I don't care if it says its compatible, I wouldn't risk clogging up my cooling system. G12 isn't all that expensive, and unless you have a leak, you shouldn't really need to use it all that often anyway. |
And I can't believe a dealer actually would be using such a product since they would open themselves up to a potential lawsuit not only from the consumer but from VW USA for not using the proper VW approved product. So I seriously doubt that this dealer is using DexCool ![]() |
The main issue with coolants is that VW's MUST use a phosphate free coolant. It's the phosphate that causes corrosion similar to electrolysis that reacts with the two different metals, aluminum in the head and cast iron in the block.
So, unless the coolant specifically states that it is phosphate free do not use it. Play it safe, use only VW approved coolant either OEM Pentosin or Autobahn coolant. Both can be found online or at the dealer. And, to restate what everyone has said here, G12,G12+ and G12++ are all interchangeable and mixable with each other. DO NOT under any circumstances mix G12 with G11(blue) coolant. That is all. |
so i went and pulled the service file for my vw and it clearly states installed G012A8G1G coolant. i looked up this part # and it says g12 coolant which should be pink but mine is clearly orange. suggestions on what to do here. I mean i clearly paid to have my timing/water pump service done and it was at an official vw dealer. The owner also has a chevy dealer so maybe they put in something else like dex-cool. ive been running this coolant since 8/2/12 and nothing has gone wrong.
Ardeca Lubricants ALU Freeze G12+ Life Long Anti Freeze Coolant Concentrate,View anti freeze coolant,Ardeca Lubricants Product Details from VROMAN NV on Alibaba.com
Here is some G12 that looks pretty orange to me. ![]() Here are some images from Google that should put your mind at ease: https://www.google.com/search?hl=en&...OOvxyAHk04CIBg |
| Coolant temp indicator/coolant temp sensor | terror_storm | 1.8 Liter Turbo | 2 | 11-07-2010 04:05 AM |
| g12 coolant ? | Wombat99VW | New Member Forum | 1 | 10-11-2009 03:13 AM |
| Oil in coolant... | ldefoggi | 2.0 Liter Gas | 9 | 09-18-2009 02:04 PM |
| G12 coolant mix | mulligania | 1.8 Liter Turbo | 6 | 06-13-2008 01:15 AM |
| Coolant Leak - D/S - Coolant Flange | Scarab 1 | Questions, Issues, Concerns, or Problems with the New Beetle | 17 | 06-28-2007 12:16 PM |
