Oil pressure light off at idle on at 1500 rpm - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > 1.8 Liter Turbo
1.8 Liter Turbo Discussion area for the 1.8 liter turbocharged engine.
Old 12-13-2012, 11:11 PM
Default Oil pressure light off at idle on at 1500 rpm
Hello from Kansas! I am working on a 2001 GLS. Well my son and daughter-in-law have had this beetle sitting in the grass for almost 2 years because the oil pressure light comes on. My son took off the pan and cleaned things up but after a few miles the light came back on so it has been sitting.
My wife suggested I fix it to help them out, so here I am. Most cars I have had oil pressure issues with are just the opposite, they are good when the engine is cold, but as it warms up the light starts coming on at idle. This car starts and drives fine for a few miles then the light comes on with the RPM's up, but if you bring the RPM's down the light goes out. Unless the pressure system on this car expects different pressure at various RPM's that makes no sense. Most cars have a dangerous PSI in mind when the light comes on, and increasing the RPM's will get you over that threshold and put the light out.
I noticed a strong chemical smell from the oil, which I suspect is some sort of flush my son used in the oil before he took it apart. I drained the oil and could see black sludge come out in the clean oil as it drained. I removed the pan,the pick up tube, and the plastic cover. Everything looked pretty clean. The pick up tube was clean from end to screen. The oil pan has tons of black sludge particles floating around in it, but it is clean. I pulled the oil pump expecting the passages to be clogged, but it also was clear. What I did find that I do not like is damage to the oil pump gears. I assume the groove is not supposed to be there, and that the rough end on the tooth is supposed to be smooth.
My question is what caused it? Did something fail internally in the pump or engine. Is it damage due to the previous severe clogging? Any ideas?
Reply With Quote Quick reply to this message
Old 12-13-2012, 11:23 PM
IndyTom's Avatar
Indianapolis, IN, USA
Car: 2012 Tornado Red VW Beetle Tsi
Is this a 2.0 or 1.8 VW Beetle? If there was sludge in the pan then the improper oil was probably used. Only use VW approved synthetic oil in the Beetle since they did have issues with sludge build up.
Castrol Edge 5W40 is what VW puts into the Beetle if you take it there for an oil change. Other VW approved oils are Mobile One 0W40 and Castrol Edge 0W30. Once sludge is in there it is very difficult to remove.
Not sure what would have caused the oil pump to fail but it seems that is the reason the Oil pressure light comes on.
Here is an oil pump for the 2.0 liter engine:
Volkswagen New Beetle 2.0 > Search > Oil Pump > ES#1876862 Oil Pump - 06A115105B
Here are pumps for the 1.8
OEM / Performance Parts for Audi, BMW, Mercedes Benz, Mini, Porsche & Volkswagen - ECS Tuning
Might as well pick up an new Oil pick up tube while you are at it.
The gears inside should look like this:
Good luck.
Old 12-13-2012, 11:48 PM
Fairfax, VA, USA
Car: '03 Vert GLX 1.8t 6 speed Tip
Replace the oil pickup. It's only about $20. If you look at it closely you will likely see it is restricted with what appears to be carbon particles. This is a COMMON problem with the 1.8t, basically coking/cooking the oil.
If you think the oil pump needs to be replaced, good time to do this as well.
There will likely be some deposits in the oil pan, but not heavy sludge like you would expect.
You may also need to replace the oil pressure switch as well.
May want to run some AutoRX through the motor once you get is back together.
Then make sure your thermostat is working and plan on a timing belt & water pump replacement before you think you are in the clear.
Old 12-13-2012, 11:52 PM
Thanks for the info. It is a 1.8 Turbo. I need to ask my son what oil he had in it. Whatever cleaner he put in it seemed to have broke lose tons of sludge. I will make sure to put the correct oil in it if a new pump does it.
CB
Old 12-14-2012, 12:37 AM
Fairfax, VA, USA
Also replace the oil pickup while you are in there!
Old 12-16-2012, 01:59 AM
New oil pump installed and no leaks or oil light on after 6 miles!!! I took the old pump apart and it sure looks like something went through it. Thanks for your inputs!
Old 12-16-2012, 03:18 AM
IndyTom's Avatar
Excellent!
Glad to hear she is up and running again!
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the NewBeetle.org Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Include me on the map?
Select this if you would like to show your location on the world map of NewBeetle.org members. City, state/province, country, and zip (for USA members) must also be filled in.
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Low Oil Pressure light keeps going off. Burky 1.8 Liter Turbo 28 10-09-2013 04:07 AM
Got 2001 Beetle checked. Oil pressure light AND "engine too cold" light going crazy Scooteroo Questions, Issues, Concerns, or Problems with the New Beetle 7 04-26-2012 04:32 PM
Oil Pressure at Idle Problem? Cold/Warm BillyMagnum 1.9 Liter TDI 2 04-05-2012 06:43 PM
Oil pressure light Uncle Chuck 1.8 Liter Turbo 11 12-21-2011 04:46 PM
red oil pressure light Slow_bug 2.0 Liter Gas 5 11-24-2010 02:11 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
