| 2.0 Liter Gas Discussion area for the venerable 2.0 liter 4-cylinder engine. |
Not wanting to take the head back off I need to know what bent valves sound like, what sounds will be made when it happens and how the engine will act if there are any. So far the only issue I'm having is it runs like crap at idle, but seems to run fairly well otherwise. Never having damaged an engine I can only guess bent valves would be obvious, even if slightly bent.
2003 Mellow Yellow GLS ragtop, 2.0 stick, Monsoon Divorces and VW mechanics; expensive but worth it |
Run a compression test. I had a car that burned a valve and was running on 3 cylinders. It ran but it barely idled and it had the weirdest sound, you could totally hear the constant miss.
2000 Cyber Green 3.2 24v |
When I turn the engine over by hand I don't hear or feel any interference and, as expected, is difficult to turn on the compression stroke. Being out only 1 tooth or so I'm hoping to have dodged a bullet.
Considering I'm still having issues with what sounds like a bad vacuum leak I'll most likely pull the intake again and run the compressions check anyway, just to eliminate the valves. |
It will look and sound like this:
https://www.youtube.com/watch?v=pYPT...e_gdata_player Maybe not as severe... But that's pretty typical of what you get if you snap the belt and just put another one on. And no, it shouldn't happen if you're just off by a tooth or two
██████ Amanda Audi - Freddy Fox - Chester Bug | LULZ | FIP - H*R - My Videos
Mercenary. Employee. Lover. Brother. Civilian. |
Ouch! I hate noises like that from engines! Lol |
Ever see the episode where the star, "Michael," puts a bunch of silverware in a microwave and turns it on to create a bomb?
That's probably not what it will sound like. Maybe putting silverware in a garbage disposal will replicate the sound. ![]() |
| 2000 Parts car and 1998 with suspected bent valves in Vermont | asnowsquall | Parts and Accessories | 121 | 07-09-2010 04:19 AM |
| Help, keep bending valves........... | 340x | Styling Modifications | 3 | 10-12-2009 01:37 AM |
| valves | buggin2662 | 1.8 Liter Turbo | 7 | 04-21-2008 03:05 PM |
| Bent Valves, Damaged Pistons, Now What?? | 5lugRS | 1.8 Liter Turbo | 16 | 04-10-2008 11:38 AM |
| Bent Valves? | ssinema | 1.8 Liter Turbo | 7 | 01-15-2008 01:43 PM |
