Normal voltage output from alternator? - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > 2.0 Liter Gas
2.0 Liter Gas Discussion area for the venerable 2.0 liter 4-cylinder engine.
Old 01-16-2013, 08:59 PM
Montreal, QC, Canada
Default Normal voltage output from alternator?
Hey,
I just replaced a faulty 90amp alternator on my 2004 New Beetle Cabrio w/2.0L 8V BGD engine with a new 120amp. Before the alternator put out around a low 14.10 volts at idle with nothing but the engine running (no lights...ect) and with this new one at idle it hover around 14.70 volts. Does that seem a bit high?
Thanks
Reply With Quote Quick reply to this message
Old 01-16-2013, 09:12 PM
Rochester, NY,
Car: 1999 GL 2.0
The Bentley manual says that at idle the voltage
"should be roughly between 13.8 and 14.5, depending on temperature and operating conditions. If the voltage is much higher than 14.5 volts, the voltage regulator is most likely faulty."
I would say that 14.7 is on the edge of "much higher." Why don't you try checking the idle voltage again after driving several miles so that the battery is fully recharged and everything is warmed up. See if it goes down some.
Old 01-16-2013, 09:35 PM
I had the battery on a automatic trickle charge while it was out of the car during installation of the new alternator. Upon hooking up the battery it had a a charge of 12.8 volts.
Old 01-16-2013, 09:43 PM
Rochester, NY,
Car: 1999 GL 2.0
That is right at the upper limit of what a battery's voltage should be. It could cause the idle voltage to be at the upper limit as well. I still say drive it some and check it at idle again. You won't damage anything until you get to 15.5-16 volts.
Old 01-16-2013, 09:56 PM
Alright I'll take it out and see what happens
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the NewBeetle.org Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Include me on the map?
Select this if you would like to show your location on the world map of NewBeetle.org members. City, state/province, country, and zip (for USA members) must also be filled in.
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Output test for fcm sevassusej 2.0 Liter Gas 1 11-16-2012 02:47 AM
Could I put a 120Amp voltage regulator on a 90 A alternator goranero 2.0 Liter Gas 3 12-23-2009 03:11 PM
High output alternator.. VeeBugTurbo Questions, Issues, Concerns, or Problems with the New Beetle 2 12-13-2009 07:41 AM
Weak Heater Output meld Questions, Issues, Concerns, or Problems with the New Beetle 2 01-27-2007 11:05 PM
armed output wire ta79pr Car Audio 1 10-23-2005 06:55 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
