Neuspeed 8mm wire set - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > Discussion - Technical > Technical Modifications
Technical Modifications The place to discuss technical and performance related modifications for the New Beetle.
Old 02-04-2013, 07:46 PM
Default Neuspeed 8mm wire set
I need to get a new set a wires and I was wondering if anybody knows anything these Neuspeed 8mm wire set. NEUSPEED 8mm Wire Set. I want to know if its worth it for performance or is it just as good to get the stock ones.
Thanks
Old 02-04-2013, 08:09 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
Unless you're heavily modified, you probably wont see a difference. If you want to add a bit of color to the bay, and get the same 8mm low resistance wiring, you can always go with a set of Magnecor wires. They're a lot cheaper for basically the same thing with better (IMHO) plug sockets. I bought both of my sets from ultrarev, and the Magnecor wires have a lifetime warranty
Mercenary. Employee. Lover. Brother. Civilian.
Old 02-05-2013, 03:45 PM
Default Wires
Thanks. I am going to get a set of these also much cheaper.
Old 02-05-2013, 05:01 PM
Toad's Avatar
Mableton, GA, USA
I actually got the 8.5mm kv85's
4 wire to 3 wire fan conversion??? empigt Technical Modifications 7 10-19-2012 12:04 AM
Where is this wire? squirreljuice Car Audio 3 08-07-2011 09:36 AM
antenna adapter blue wire? k-wire? charmingtrouble Car Audio 6 01-21-2011 01:26 PM
ABS Wire jazzman_q 2.0 Liter Gas 0 07-18-2006 11:28 PM
wire harness angelusnhc Car Audio 7 10-15-2005 06:09 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
