Caractere Front Grill Install - How-To - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > How-To's > Styling How-To's
Styling How-To's Detailed steps on how-to perform various styling modifications and tasks.
Old 09-16-2005, 05:26 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
Default Caractere Front Grill Install - How-To
How-To by redbaron
Caractere Front Grill Install (how-to)
Since my instructions came in French, for those of us here in the Good ol' U.S. of A may appreciate some English along with some pictures. In addtion to the kit that you receive, I recommend the following tools:
Screw Gun
Hack Saw
Diagonal Pliers
Dremmel Tool
Screw Drivers (flat and Phillips)
Torx set (T-20, T-25, & T-10)
Drill Bits
1 Piece of Rubber Door Guard Protector
marvins_dad ~ antoine
Old 09-16-2005, 08:00 PM
I BELIEVE!
Dallas, TX, USA
Steps
OK let's start.
1. Cut lower bracket by following the instructions that came with the kit. You need to come in 30 cm from each edge and cut the lower middle out. There is a plastic rivet that you will need to drill out in center bottom. See picture:
Old 09-16-2005, 08:01 PM
I BELIEVE!
Dallas, TX, USA
Once you have made the cuts, the bar is held in place by small tabs that are inserted into the stock plastic mesh grill.
You end up with the following:
Old 09-16-2005, 08:02 PM
I BELIEVE!
Dallas, TX, USA
Closer:
I BELIEVE!
Dallas, TX, USA
Next, take out the center bar. You will need to make cuts on the far ends, and on the insides of the fog light housings. (total of 4 cuts) See pics:
Old 09-16-2005, 08:03 PM
I BELIEVE!
Dallas, TX, USA
Heres why you don't need to cut both sides of the fog. The end closest to the fog is tucked under & free. 1 tab to pull:
I BELIEVE!
Dallas, TX, USA
Here's your end result. You are now ready to pull the fog cover off. It's held by tabs.
Old 09-16-2005, 08:04 PM
I BELIEVE!
Dallas, TX, USA
Close up of the housing & how close to make your cuts:
I BELIEVE!
Dallas, TX, USA
Your current grusome sight:
Old 09-16-2005, 08:05 PM
I BELIEVE!
Dallas, TX, USA
Close-up of fog housing:
I BELIEVE!
Dallas, TX, USA
Close up fog without shroud:
Old 09-16-2005, 08:06 PM
I BELIEVE!
Dallas, TX, USA
At this point you will want to smooth your edges and sand/dremmel/or file the plastic that you have just cut to make everything flush.
Once completed you are ready for the PITA of the install, the placement of the inlet grills. The center is a no-brainer. Line it up and screw it down. The two outside inlets with the fogs are tough. What we found is this, from the inside edge, place the shroud and then give yourself an extra 1/4 ". This is a good start point. Screw the grills in and put the shrouds back on the fogs (one at a time) and then do a test-fit by brining the whole caracter piece and mating it with the car.
NOTE: We used a piece of rubber door guard to cover the sharp edge of the cut grill so it would not scratch the housing. (We thought of it after we test-fit and scratched the housing-DOH!)
I BELIEVE!
Dallas, TX, USA
Close up with rubber door guards:
Old 09-16-2005, 08:07 PM
I BELIEVE!
Dallas, TX, USA
Lastly, mount the new piece. There are 2 screws that attach the pice to the frame on the bottom (see your Caractere instuctions) then you'll have 4 crews left, 2 per fenderwell to secure the wrap-arounds.
NOTE: Caractere includes an epoxy to attatch the grill. We opted NOT to use the Epoxy at this time as the fit was snug and secure. We figured we could always come back later and un-do 6 screws and epoxy the piece if need be. You'll need to make your own decision based on how you drive & how often you drive the vehicle.
Special NOTE: The Grill mod is 1/8 " lower than the stock grill.
Finished product:
I BELIEVE!
Dallas, TX, USA
If you have the license plate holder, you will need to mod it to fit the new configuration. Dremmel tool works well here. If you are fortunate enough to live in a state where the front plate is not reqired, cover the holes and go.
Old 09-17-2005, 02:17 AM
I BELIEVE!
Dallas, TX, USA
To discuss this How-To please visit the link below...
Caractere Front Grill Install - (How-To) -Discussion Thread<---click here
Front Grill Removal - (How-To) - Discussion Thread marvins_dad Styling Modifications 58 08-14-2011 04:36 AM
Caractere Front Grill Install - (How-To) -Discussion Thread marvins_dad Styling Modifications 7 04-25-2009 10:26 PM
Front and Rear Euro Emblem Install - How-To marvins_dad Styling How-To's 7 09-19-2005 06:44 PM
Front H&R 26mm Sway Bar Install - How-To marvins_dad Technical How-To 31 09-17-2005 05:28 AM
Front Grill Removal - How-To marvins_dad Styling How-To's 1 09-17-2005 05:22 AM
