Should be only concerned with inside diameter; which should be 1-3/16". I ordered it from -
http://www.acautotechnic.com
You can also get a nice ones from -
http://www.egauges.com/
or
http://www.marshallinstruments.com/
Take a look at this thread, I've already gone through this.
http://newbeetle.org/forums/technical-modifications/
BTW, if you're unsure, get a caliper type ruler at Lowe's or similar for about $10 or so. Then slightly ajar the hose attached to the upper coolant hose then measure. I believe this is one of the ways to be 99% sure of the hose's inner diameter, which is needless to say, the one you need to know.
DD
Originally Posted by vgmnstr
Anyone know what inside/outside diameters are for the upper and lower radiator hose for the ALH TDI 1.9? I am looking to add a new temp sensor and I can buy adapters to put the sensor in the radiator hoses. I just need to know what size the hoses are. Thanks.
V
2006 New Beetle
TDI 5spd, Cream Exterior/Beige Leatherette Interior, Monsoon CD/MP3/SAT, Sunroof. 43K+ Miles on the clock. UNIDEN 538W CB, Firestik 3' Antenna, Hardwired Valentine1 X/K/Ka/Laser Radar Detector,
ProParts Dual Gauge A-Pillar Pod with New South Indigo Boost & Water Temperature Gauges, connected to the dimmer switch for a perfect factory gauge match. Watch the video clip! http://www.youtube.com/watch?v=-iZv39lnmAs, Hardwired Craftsman Garage Door Opener
