Door Panel Help - NewBeetle.org Forums
Old 12-16-2007, 10:34 PM
sarlen's Avatar
Default Door Panel Help
So another of the many things wrong with my NB is the drivers door panel is cracked and the electric window controls don't sit in it just right. I want to take the door panel off but wanted to get some advise from you old pros on removing them before I tried. I do not have a trim tool for VW, do I need one?
Old 12-17-2007, 12:39 AM
boblamb58's Avatar
Send Money
Levittown, PA, USA
Car: 2008 Scion xB 5-speed manual in Nautical Blue Metallic, 1999 Honda Shadow 750 ACE Deluxe
Three torx across the bottom (no. 10 if I am not mistaken)
Gently pry of the handle cover trim to reveal 2 Phillips screws.
The panel can now be pulled away from the door except for at the top.
To get the panel off, you have to disconnect:
Courtesy Light
Window Switch Connectors
Gas and Rear Hatch Connectors
Powered Mirror Connector
Make note of which connector came from where!!!!
Now the hard part... The rubber weatherstrip across the top of the
panel is a PITA to get out, but with gentle but hard upward pressure
it will release eventually.
One more thing to disconnect before you are done:
Cable for the door lock. Can't really reach it until the door
panel is out of the door top.
Television is more interesting than people. If it were not, we would have people standing in the corners of our rooms. If parents would spend less time worrying about what their kids watch on TV and more time worrying about what's going on in their kids' lives, this world would be a much better place.
Door Panel Vinyl El Diablo Questions, Issues, Concerns, or Problems with the New Beetle 12 08-26-2011 11:09 PM
door panel paranoia mkellyrock Questions, Issues, Concerns, or Problems with the New Beetle 3 04-11-2007 10:38 PM
2000 door panel Bio-Beetle Market Place Archives 1 03-28-2007 07:16 PM
Door panel removal? turbobug17 Paint and Body 1 06-09-2006 09:34 AM
Remove Door Panel s_santiago Styling Modifications 2 01-16-2006 07:02 PM
