Wheels question... - NewBeetle.org Forums
Old 07-17-2008, 10:18 AM
WhatTheVDub's Avatar
That LGBT Member..
Pensacola, FL, USA
Car: 1998 New Beetle 2.0
Default Wheels question...
What's the Largest offset that will fit?
Old 07-17-2008, 10:58 AM
Basher's Avatar
Huskvarna, Sweden
Car: 1999 Techno Blue 2.0
That depends on the width of the wheel, the tire size and the axel of the car. Plenty of combinations fit (too much for me to write down here), which one do you want to mount?
Old 07-17-2008, 12:56 PM
That LGBT Member..
Pensacola, FL, USA
http://www.rojawheels.com/archive/wh...ver&style=2092
I believe this is the size of the tire: 225/45/17
It's a 98' VW Beetle, im not sure what trim, it's a 2.0L Petrol.
Old 07-17-2008, 03:26 PM
SMGNewBeetle.org Member Sponsor SMG is online now
ET42 should fit, but you could definitely use some spacers to make them look right. I ran 5mm spacers on an ET32 wheel so you'd probably want 10mm front and 15mm rear spacers.
Old 07-20-2008, 04:00 AM
That LGBT Member..
Pensacola, FL, USA
Why put 10mm on the front with 15mm in the rear? wouldn't that make it look funny, making the back tires look wider? It's not like its rear wheel drive.
Old 07-20-2008, 04:25 AM
You have no friggin clue do you? The rear wheels are set further into the fenders so a wider spacer out back evens it out.
Old 07-20-2008, 03:03 PM
Picknicker's Avatar
Germany
Car: '99 2.0i
Also the rear tires are mainly responsible for the car's ability to keep in track... Wider tires in the rear (and a wider track) allow you to take corners way faster than with smaller tires...
Old 07-21-2008, 01:30 AM
raff's Avatar
Proud TOD Maiden Voyager
Valdosta, GA, USA
Car: 2006 Jetta 2.0t, 2006 Miata MX-5
I always thought it was the front wheels (in a front-wheel drive car) that had the greater influence on cornering.
The answer is blowin' in the wind....thanks to PP&M
Old 07-23-2008, 03:13 AM
That LGBT Member..
Pensacola, FL, USA
I didn't meant to come off like an ass****. Just wondering was all.
What is a good wheel spacer brand to buy?, something not expensive but well made.
Old 10-06-2008, 05:43 PM
Seanele's Avatar
Phillips Ranch, CA, USA
Car: '09 Jetta (Candy White), '07 Yaris 3dr (Metalic Blue)
I'm also looking for spacers and so far all pointed to H&R brand.
they're not cheap but the best out there.
Last night I saw ECS on eBay, $107/pair of 17mm, bolts included.
I want to go with that, but still hoping for H&R.
pcv valve question and oil question a_magoo 1.8 Liter Turbo 3 10-07-2006 01:31 AM
Wheels ordered, question about seats HungLo Styling Modifications 3 06-29-2006 04:57 AM
p 0411 code question and coolant leak question.... bobbittle 1.8 Liter Turbo 5 06-12-2006 02:47 PM
Looking for these wheels wtb 99dub Styling Modifications 10 03-17-2006 01:16 PM
