Turbo S Turn Signal. Help! - NewBeetle.org Forums
Old 09-19-2008, 07:29 PM
Drivers Wanted
MIAMI, FL,
Smile Turbo S Turn Signal. Help!
hii guys!
I have been searching here on the newbeetle.org boards and i was trying to find out how i can put the turn signals that the Turbo S brings in the front. Is that even possible to put on another beetle?
I have a 2002 New Beetle GLX.
I was wondering if you guys new anything that could help me on this!
thanks alot guys (:
Old 09-19-2008, 07:31 PM
GINA's Avatar
Custom User Title, go!
Baltimore, MD, USA
Car: 2008.5 Mazdaspeed3
You would have to get the entire Turbo S front bumper
Old 09-23-2008, 09:08 AM
beastle's Avatar
that's what she said...
Sacramento, CA, USA
Car: 2003 1.8T Beetle, 1994 vr6 passat
Are you talking about the small lights near the head lights? I believe those are just running lights. I don't think they work as blinkers also. I could be wrong.
BEASTLE
Old 09-23-2008, 03:40 PM
hestersu's Avatar
Canyon, TX, USA
The round lights to the inside of the headlights are blinkers. The lower lights on the corners of the fascia are running lights (same shape as the rear running lights).
The only way to get the round lights is to cut up your fascia and split the wiring from your existing blinker/corner lights or buy a Turbo S fascia along with all of the related needed parts and still split your wiring. Unless you can get a dirt cheap fascia complete with all the parts, you are looking at $1,000 plus painting. It can be done (I've done it) but you need the cash to do it.
FYI - if you have a 2006 or newer bug, the Turbo S bumper will not fit.
Susan Hester
Former owner of:
Old 10-06-2008, 05:45 AM
My 2004 turbo doesn't have the holes in the fascia for blinkers. Was this an option or is it just on other years for the turbo?
Old 10-06-2008, 09:13 AM
VW Lady Bug's Avatar
Lay Lady Lay
Aston, PA, USA
Car: 2002 Turbo S
limited to only the Turbo S from 02 - 04.
Current VWs owned: Lady (2002 NBTS), Lola (2008 Rabbit), Tracey (1994 jetta glx)
Previous VWs owned: Kitty (99.5 Cabrio), Goldie (90 Jetta)
fast turn signal 676cyl 2.0 Liter Gas 9 04-15-2012 07:06 PM
Turn signal 4toyhln 1.9 Liter TDI 2 10-04-2008 04:53 PM
Turbo S front turn signal v5bugse Questions, Issues, Concerns, or Problems with the New Beetle 2 03-16-2008 01:32 PM
Turn Signal Lights Kenya_7 Parts and Accessories 7 11-07-2007 02:39 AM
turbo-s front turn signal ? uf_gators Technical Modifications 4 07-14-2007 06:20 PM
