Did I ever tell you that you rock out loud!? ![]()
Looks good Howie...the other pic just didn't look right. Looks like they could use a little fine tuning on the aim. How do you like them so far? Better than the kit that you had? Or did you never have one? I can't remember.
How did the wiring go? Did you put a fuse inline between the battery and the relay?
Nope, I didn't have the kit. From what you and someone else was saying I decided to try to do it right for once.
I haven't actually been out at night lately, but the short drive I did take nobody flashed me, so I guess the aim is ok. What do you see that is wrong? I wired the ballasts directly to power with no fuses or relay. Am I bad? The stock plug goes into the headlight as before, and the original wires that went to the halogen bulb exit to the ballast, then back into the new bulb. Howie roswell 2k: the 10th anniversary - new beetles return to roswell |
I will update in a day or two. You guys really should be using a relay harness to pull power directly from the battery to save your stock wiring and switch. I believe I posted some info on this earlier in this thread.
Again, I will try and help you guys out with that in the next few days. |
This is the quick and dirty info, let me know what doesn't make sense and I will fill in the blanks.
I'm just wondering, this is slightly off, but can you guys take a picture of the headlight cluster from the outside of the car? I'm curious to see how the finished product looks.
Thanks! |
bump for update again!
I bought the ddmtuning hid kit that crazymofo recommended. I got the ones under the slim ballast ones. Do you know if the regular ballasts will fit in the space behind the headlights in that little fender hole on page 1 or 2? |
my first hid kit was just a regular ballast and it didn't fit in the cubbies I had to mount them elsewhere... slim ballasts have been the only ones that have fit so far, but your ballasts may be different who knows...
BUGGEN' 4 UBUGGEN' |
I'll take some pics of my alternate ballast mounting location. No clunking ballasts and with my rigid Koni yellow + AP spring setup on battle-torn winter roads here in Ontario they have not moved an inch! It was a PITA to mount them though (thx Turbo-Christ0)
@ canned3ggs: Can I meet you somewhere to take a look at your HID setup? I am not far from Pac Mall. -DT
(o\_I_/o)2004 TS::. Reverse engineered from UFO's(o\_I_/o) Last edited by Downtown Turbo; 01-27-2010 at 01:25 AM.. |
Thanks for answering my questions!! Pictures of everyone's ballast mounting would be great.
I hope i won't have regrets on not spending an extra $10 for the slim ballasts... |
| daytime lights and hids | 1FSTBUGG | Technical Modifications | 2 | 01-10-2008 01:39 AM |
| hids in a 03 turbo bugg | 1FSTBUGG | Styling Modifications | 11 | 11-30-2007 04:21 AM |
| New member - HIDs worth it? Turn signal bulb replacement | Krzys | New Member Forum | 6 | 02-02-2007 05:08 PM |
| Are there hids for nb | madison04 | Market Place Archives | 2 | 12-17-2005 03:10 PM |
