Made? No. But I had some welded on that you can buy for the Beetles...
Bumbls : 2011 Ford Transit Connect XLT
Sting : 2002 1.8T Beetle Color Concept My FLICKR: See My High-Res Photos Here Cameras I Use: Canon Eos 40D |
I got them from a fellow org member here
![]() There is one just like it on eBay right now for $95 .. which is a GOOD price. If you bought them from VW , they cost 2-3 times that much. Hope that helps ![]() BUT, if I might make a suggestions? Don't spend $100 on exhaust tips. for $470 you can get the entire Magnaflow exhaust upgrade for the Beetle and you'd be so much better off with it. Power upgrade, sound upgrade, and it has tips on it already. ![]() |
Thanks for the suggestion. I like your idea. ![]() Will Google this. Last edited by ghostRder1; 08-21-2009 at 03:25 AM.. |
No power upgrade to be had from exhaust despite popular opinion.
Agreed. On an otherwise stock engine...no difference. On a N/A 2.0 - no difference.
On a significantly modified TDI or 1.8T - it keeps the EGT's down allowing you to do more power mods to the engine. The actual exhaust itself might only add 5 hp or so...but that amount of power is hard to measure (within dyno tolerances) and it is hard to feel. |
Now on my 2.0T I noticed a big difference going from a stock cat with a 2.25" catback to a 2.5" turboback. The turbo used to almost choke out between shifts and the turbo spools faster now. On a non-turbo car an exhaust is just going to make more noise.
I know this is an old thread...but interested in putting the tips on my '08 NBC... I found some on eBay that were about $50 cheaper than ordering thru VW part #ZVW-806-001-A ... my question is do these just bolt on like the Golf version? or are they welded?? When I had the dealer parts guy look up the tips for the bug he was surprised they were $60 more than the Golf's and that they needed to be installed differently...he didnt say how just they were more complex than Golf which had set screws....I can handle screws...cant handle welding lol....
this is ebay listing if it helps: thanks in advance for advice ![]() |
well i would agree on a lot of cars, but i have seen them installed on a beetle and you couldnt see from the side unless maybe if u were on the ground...plus the current exhaust is still under warranty even...if it was older model i might considering getting new system but cant justify it for nice tips...$90 i can justify...especially if i can install myself...i cant install an exhaust system ;-)
thanks for the info. I ordered the one from ebay...as it was screw on type and came with instructions plus its $60 cheaper than dealer wanted for same part....so we shall see...hopefully it will help eliminate the black buildup on the bumper and look pretty...as long as I keep shining them of course lol.
![]() Last edited by LittleYellowVW; 05-11-2011 at 06:10 AM.. Reason: because i spell bad =) |
| Which exhaust tips? | MichelleRoze | Styling Modifications | 22 | 09-06-2010 08:35 PM |
| Fs: Exhaust Tips | Vitric | Market Place Archives | 1 | 06-18-2007 08:51 PM |
| OEM exhaust tips | Green Arrow | Technical Modifications | 13 | 06-07-2007 06:13 PM |
| Exhaust Tips | BettyBug | Market Place Archives | 3 | 08-15-2006 10:24 PM |
| Exhaust tips are they all the same? | madison04 | New Beetle Convertible | 5 | 04-18-2006 06:02 PM |
