foglight help - NewBeetle.org Forums
Old 03-09-2010, 01:47 AM
lw462's Avatar
Default foglight help
Hope this is the right forum for this question.. I have a 98 with fogs and right now I only have one light assembly thing. The other connector is attached and some plastic is missing. I was wondering whether you could help me determine is the connector is still good; I want to order a new assembly and stuff but there is no point if the connector is bad..Ill show some pictures.
my first beetle: lil red/red! 98 2.0 5spd beauty hehehe
Old 03-16-2010, 02:02 PM
farfrumsanity's Avatar
OH, USA
That is the connector that fits into the rear of the foglight,
it appears to have dragged on the ground. You can connect the terminals and fill with silicone sealant to waterproof or replace the plastic connector, I don't know if its available separately.
Old 03-16-2010, 10:34 PM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
You can try 1J0973722, should be around $15 at the dealer. I think that is just the housing without the wires or contacts.
OEM vs aftermarket foglight ph34r Questions, Issues, Concerns, or Problems with the New Beetle 2 09-07-2009 12:51 AM
HID kit for headlight and Foglight wchoi919 Technical Modifications 12 06-02-2009 04:28 PM
How to turn off foglight? shnana Questions, Issues, Concerns, or Problems with the New Beetle 4 03-04-2009 02:30 AM
Foglight delete wfg97079 Styling Modifications 2 07-10-2006 08:05 PM
foglight bulb replacement on 99 new bug E-AT_me Questions, Issues, Concerns, or Problems with the New Beetle 2 10-30-2005 01:10 AM
