wheels - NewBeetle.org Forums
Old 02-09-2011, 09:48 AM
Default wheels
just wondering if can fit 114 pcd wheels to new beetle. is it possible?
Old 02-09-2011, 03:30 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
Car: 03 Red Turbo S, 66 Ford Galaxie
There are several different companies that make adapters to fit almost any wheel/car combo. What you need to know before you can answer the question is what the offset of the wheel in question is. The thinnest adapter you can get (I think) is about 15mm. So whatever the offset of the wheel you want, minus the thickness of the adapter is what you need to know (final offset). If your final offset is less than 35mm, depending on your wheel width, is goona start poking.
Need to know: wheel width and offset
wheel adapter thickness
Old 02-09-2011, 09:47 PM
thanks for the reply dude. wheels advan rs/rz 18x8 +35 all around but with 114 pcd
Old 02-09-2011, 10:16 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
How low are you sitting? With that offset combined with a spacer/adapter, you're gonna poke a bit. Can you test fit the wheels? Obviously you can't mount them without the adapters, but you could take a wheel off, put one of the others up to the hub and then measure out from the lip of the wheel the distance of the spacer/adapter you choose, and see if it's something you're gonna be happy with. You're gonna want weight on the suspension when you measure.
Old 02-09-2011, 10:28 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
You might end up pokin like these....
Old 02-10-2011, 01:40 AM
raymondlee's Avatar
Seeuro.com
Albany, GA, USA
Car: 98 jetta,87 jetta
though not practical, i'd lve fr laura ass to look like that
Old 02-10-2011, 02:04 PM
my beetle is still stock height, so if its poking it would look ugly imo. what offset u guys recommend to get flush look?
Old 02-10-2011, 03:07 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
Whatever wheels you get, if they are not a staggered fitment, will be more tucked in the rear than the fronts.
I would say on an 8" wheel you would want to be ET35 would get you close to flush. Without physically measuring I couldn't tell you for sure but this is probably the lowest offset you would want to use if you don't want poke and get you close to flush.
Old 02-10-2011, 09:40 PM
alright. thanks dude. i'll play safe with +45
Old 02-11-2011, 02:07 AM
Wingnut_rb's Avatar
Kennewick, WA, USA
try brfore you buy. if you go with too high offset you start rubbing on suspension parts..i.e. struts.
FS: Wheel Covers, 2 Alloy Wheels, 2 Steele Wheels kcfoxie Parts and Accessories 3 09-11-2010 03:18 PM
For Sale Audi / Vw A8 Wheels and tires 19" ALL FOUR!!! Audi or VW wheels rims - A8 Joe Cat Parts and Accessories 0 10-06-2009 02:24 AM
Wheels FIT??? Gianky Styling Modifications 13 03-04-2009 10:28 PM
My New Wheels JohnnyJet Styling Modifications 10 07-06-2006 12:41 AM
anyone seen these wheels? gilligan Styling Modifications 22 02-06-2006 03:27 PM
