The biggest you will be able to go is about 26 - 26. 3 inches in overall diameter on a stock suspension. And if you go too wide, it wont work either. I think the best you will be able to do is a 225-45-18. Still pretty low profile but that is the price you pay with 18's.
Sent from my DROID2
Sent from my DROID2 |
I believe my wheel width is 8 inches...will that size still work? |
Also, "believe" is not a good word to use when talking about tires/rims. If you try to fit a 235/45ZR18 or 245/40ZR18 on a 7" rim, you'll end up with sidewall deformation and that will not do good things for tire longevity or handling. You can usually find the diameter, width, and offset of the rim stamped on the back side of the wheel. It'll look something like this: ![]() The picture shows a 20" wheel with an 8.5" width and +52mm offset. Last edited by Judee; 04-08-2011 at 08:09 PM.. |
225/45/18 seems to be the route I'll be going guys/gals. Wheels are 7.5's. pretty excited to get them done and order tires. Will post up pics and such later. gonna be a bit before the wheels are done. thanks for all your help, if anyone thinks I'll have any issues let me know!
I'm z85 crew cab 2wd and my pro comp tire are about 29.5 tall and due to the rim size (16) and the backspacing and offset and the multiple accidents its been in the tires do rubb on the frame and sway bar at full lock
| Tire research | atc | New Member Forum | 2 | 12-01-2008 07:56 PM |
| Need tire help | MichelleRoze | Technical Modifications | 10 | 05-13-2008 05:53 AM |
| Wtb Tire | CYBERGREENCC | Market Place Archives | 0 | 11-16-2006 08:35 PM |
| Tire Gel | ghostRder1 | New Beetle Detailing/Cleaning | 5 | 06-28-2006 02:59 PM |
