WTB/I need help with my 2002 TDI Bug:) - NewBeetle.org Forums
Old 07-11-2011, 07:31 PM
Mount Vernon, WA, USA
Car: 2004 Beetle
Smile WTB/I need help with my 2002 TDI Bug:)
So i got some work i need to do and i need help with what i need and how to do it!
This is her...
I want to get some vinyl stripes but i'm still getting prices. I will also put up more pictures because i need major arm rest help.
Thanks everyone!
I LOVE my Bug!!!
Old 07-11-2011, 07:35 PM
Car: 2004 Beetle
Default Arm Rest
It keeps falling and not staying up. Also is missing the plastic cover(you can see in the picture). Is there any small part i can buy to fix it? I went to the dealership to see how much a new arm rest would be and they were saying... $350
Any suggestions?
Old 07-11-2011, 07:39 PM
Car: 2004 Beetle
Default Key
Also new keys are expensive and mine works perfect. But.... the key ring fell of is there and fixes anyone has to how i can get a new just metal piece orrrrr some way i can make one
Old 07-11-2011, 07:42 PM
Car: 2004 Beetle
I also wanted to put a diesel Emblem on my dash. Can i use any ordinary one?
Old 07-11-2011, 08:09 PM
macdave's Avatar
Olympia, WA, USA
Car: 01 1.9TDI Techno Blue
The only parts I see for the armrest are the latch, the top with the latch, the side cover and the complete armrest.
I'd pull it out and see if there is any way to take it apart and see if it can be fixed. Otherwise your best bet is to find a good used one or aftermarket armrest on ebay.
You can find a replacement shell for the key here:
haakey.com Sidewinder keys
Old 07-11-2011, 08:34 PM
Car: 2004 Beetle
How can you take it apart?
And Thanks for your help! If anyone else has any ideas please write
Old 07-12-2011, 06:45 PM
Car: 2004 Beetle
I fixed my armrest!!!!
Finally found a forum about it!
Old 07-12-2011, 11:06 PM
Oldbugman's Avatar
Jacksonville, FL, USA
Car: 2000 GLX 1.8T 5 SP
My ring comes off of my key quite often I found you can pry the to halves of the remote apart enough to slip it back into place, kinda tricky to do ( almost need 3 hands to do it) but with paitence you can get it back into place. i actually use my NB key fob to pry it open enough to get it back in, I've become quite proficent in doing it.
Old 07-12-2011, 11:11 PM
Oldbugman's Avatar
You should be able to do so using 3m double sided tape however I would highly suggest you do not adhere it to the airbag shown in the photo, it is clearly defined by the rectangular shape.
Old 07-16-2011, 07:24 PM
Car: 2004 Beetle
Welcome to our Team's Homepage Fundraiser walk im doing
Tags
arm rest , silver 2002 , tdi , wtb
2002 nb 2.0 polkabill Questions, Issues, Concerns, or Problems with the New Beetle 1 11-07-2010 08:40 PM
my 2002 NB jierumi New Member Forum 4 03-24-2009 02:28 PM
2002 vw nb 2.0 bets74az Transmission Talk 0 06-23-2008 08:41 PM
Difference between 2002 Sport and 2002 GLX Stinkbug Technical Modifications 5 07-19-2006 06:06 PM
2002 Nb Gl The Bug You Wish You Had Market Place Archives 1 12-10-2005 12:06 AM
