'06 console in an '05? - NewBeetle.org Forums
Old 02-12-2006, 06:21 PM
Cartersville, GA, USA
Car: Sunny Bug (a yellow '05 GLS 2.0)
Default '06 console in an '05?
VW has finally taken the hint about the horrible cup holders in the '05 & prior models. The new center console is what I love the most about the '06. I also love the tray below the AUX input; perfect for an mp3 player!
Is there any way to replace the '05 console with an '06 console? If it's possible, how hard and expensive is it to do?
Thanks!
Old 02-13-2006, 12:09 AM
SMGNewBeetle.org Member Sponsor SMG is online now
Everything will be swappable, the car only got a mild facelift.
Old 02-13-2006, 05:05 AM
Mr.Yellow's Avatar
I am McLovin
Bellingham aka Bham, WA, USA
hey can some one put up some pics of the new dash. compaired to the 1998-2005 dash
Old 02-13-2006, 08:32 PM
heyou's Avatar
Gaithersburg, MD, USA
Car: 2000 Cyber Green GLS, 2.0L
Seconded! I'd like ot see this as well.
Old 02-13-2006, 08:52 PM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
The changes are subtle but effective. new visor, new center floor console, totally new guage face, new vents. Not a whole lot else. There should be pics up somewhere already.
LOOK AT MY Bug!!!!
Old 02-14-2006, 07:02 AM
This giant picture gives you a good idea of the 2006 change.
It's exactly the same as the Ragster, minus the 'dildo shifter' and funky, concept car bits such as the seats, funky rear-view mirror and the steering wheel.
SMG
Old 02-15-2006, 12:15 AM
Mr.Yellow's Avatar
I am McLovin
are you sure it is exactly like that?
i really want to see a real 2006 dash. i dont want to imagin it.
Old 02-15-2006, 03:07 AM
heyou's Avatar
Oh hell yes! I think it's a solid piece around the shifter/ ebrake, I NEED one of those! I like my 2000 era dash, but I need that lower piece around the shifter. I wonder where we could get them, it means I wouldn't have to hold drinks on my lap!
Old 02-17-2006, 05:16 AM
Mr.Yellow's Avatar
I am McLovin
I jsut realized that the ragster caped off the vase. i might do that to my car so i might get less crap for drivin a "chick car"!!!!!!!!!
Old 02-17-2006, 07:16 AM
That's the 2006 dash, what part about "it's exactly the same" don't you understand?
I chose the Ragster because that shot was the only one that showed the new console, front to back in one picture.
SMG
Old 02-26-2006, 10:29 PM
tech.henderson's Avatar
NerdsOnSite.Com
Pleasant Prairie, WI, USA
I take it that it would fit a 2000 right?
Old 02-26-2006, 10:36 PM
We're assuming.
No one has actually done it.
But it's not that it wouldn't be do-able, but you might need to drill an extra hole or two if they changed screw locations for whatever reason.
SMG
Old 02-27-2006, 01:11 AM
yelojkt's Avatar
beetle driver for life
Wichita, KS, USA
The 2006 console will swap out with the older consoles except for the e-brake handle. It is moved over towards the drivers seat in the "06".
Moded to make driver grin.
Did You see Yelojkt?
Dyno Video before custom K03S
09 ZX6R Candy Blue
Old 02-27-2006, 01:26 AM
yelojkt's Avatar
Wichita, KS, USA
The 2006 dash is just like the ragster minus the mirror and steering wheel. Also making it to production from the ragster are the front and rear bumpers, fenders, and running boar/rocker panels.
Old 02-27-2006, 01:40 AM
NerdsOnSite.Com
Well not knowing too much about any modifications whatsoever but very interested in it does the e-brake pose a problem and its not swappable at all or is it? I only ask because I do not know the mechanics of an e-brake and I am unsure if its just cabling or what that would make it work.
Old 02-27-2006, 01:52 AM
heyou's Avatar
I would like ot know as well, I REALLY need decent cupholders!
Old 02-27-2006, 01:55 AM
Did you do this swap? Where did those pics come from?
SMG
Old 02-27-2006, 02:07 AM
yelojkt's Avatar
Wichita, KS, USA
The first pic is yelojkt's console (2000 GLS). The second pic is Rubie's (2006 Package 2)console. The console is just a cover over a slightly elavated center tunnel. The piviting end of the e-brake is not attached to the console but to the floor of the car. My guess is that you would have to do some metal work under the consloe to get the e-brake to sit at the proper angle.
Old 02-27-2006, 02:12 AM
Oh, I always assumed that the e-brake handle just pulled a line, and didn't fit onto an e-brake stick underneath.
Oh well, maybe someone will pull it off
SMG
Old 02-27-2006, 01:17 PM
Check out this long thread on TDI club. It discusses updating the consoles in A4 Golfs/Jettas.
http://forums.tdiclub.com/showthread...hlight=console
Starting on page 2, they talk about having to move the ebrake handle to accomodate the newer style console. I'm guessing that similar techniques will work with the New Beetle.
Bottom line for those cars: there is a different handbrake assembly that will offset the handle. Now, we just need part numbers...
WTB CD changer for center console bournehall Car Audio 2 10-02-2009 08:44 PM
Help! With getting the rest of Center Console off! kenbird Questions, Issues, Concerns, or Problems with the New Beetle 9 12-22-2008 05:09 PM
Drilling into console?? Jarhead96 Technical Modifications 12 04-01-2006 09:35 PM
removing center console slugo Technical Modifications 4 01-20-2006 07:50 PM
Center console removal ryanbutterworth Car Audio 0 10-31-2005 07:36 PM
