good job so far.
![]() i haven't done my spokes yet because i'm afraid i'll break them off the wrong way and them be screwed. and make sure you throw some polish on your finished pieces before puttin 'em back in the car, even if it's just your regular car wax. triple thick clearcoat shows triple deep scratches. (i speak from experience.)
i haven't ever polished any myself, but Fowvay said after he finished painting, he wet sanded, used a little rubbing compound (which got the paint smooth as glass), and then applied a few coats of Meguiar's No. 7 Show Glaze (which i priced ~$14 a bottle at Pep Boys).
When i paint my next parts (actually finish the ones i have laying on the bar at home waiting for clear), i plan on wet sanding with some crazy-high grit paper, and then a couple coats of either that glaze or my Tech Wax. here's what his came out like (and what i hope to achieve)... |
wet sanding would take a layer or 2 of clear off, but just put those 2 extra on to begin with.
as for rubbing compound... ![]() my dad used this stuff to strip the spray paint off my little brother's pinewood derby car when he decided he wanted a different color. he was only rubbing as hard as i do when i sand stuff. i don't think i could use it gentle enough to not go through my color coats. |
Wet sanding will flatten the clearcoat surface and if done right should not even go through you top clear coat. When you are finished your paintjob will look dull (almost like a matt finish) then you use the rubbing compound to bring out the shine in the clear, and have that deep paint look.
Moded to make driver grin. ![]() Did You see Yelojkt? Dyno Video before custom K03S 09 ZX6R Candy Blue |
I dig it all... but you should head over to the missing bite, throw them about $4 and buy an oval euro Apple logo (100% vinyl, easier to remove, and it looks a bit nicer than the standard issue ones). Just something to think about
I'm going to go buy some rubbing compound and do it to those door handles. Then I'll take more pics and let you know how it comes out. Last edited by iScott; 03-27-2006 at 01:33 PM.. |
One of the paper salesmen we deal with gave me a good tip for post-clear coat sanding. He said that using a really fine steel wool pad would work well, followed by a good wax. A good example is this:
http://products3.3m.com/catalog/us/e...r/output_print I'm gonna grab some of this at Home Depot and use it on my door handles later tonight. |
thats why FineExampl has been trying to see which chemicals eat away the rubbery gunk best. he was trying out the different things on his little pieces to find which works best and quickest before moving on to his center dash console. plus you have to take a lot more care in spraying and finishing big panels like those. |
Talking about the center dash console....how exactly are you supposed to paint that? does it pop off someway? if so, how? |
| Stuff on my cat | GINA | Miscellaneous Hoo-Ha Archive | 22 | 05-04-2006 04:35 AM |
| Interior Painting | woj1978 | Paint and Body | 8 | 03-01-2006 08:42 PM |
| anyone get stuff at TVA? | yellow99 | Styling Modifications | 11 | 01-01-2006 10:19 AM |
| Need alot of stuff | K-BL | Market Place Archives | 2 | 12-20-2005 02:13 AM |
